Xkr 2001 , roof work
Old Oct 1, 2010 | 03:34 AM
tanngo's Avatar
Default Xkr 2001 , roof work
hi guys, my 2001 xkr cabriolet, roof work
Front windows do not
drop/raise for easy
open during top
operation,
The windows require programming.
Old Oct 1, 2010 | 07:47 AM
coupeman's Avatar
Hi tanngo, all you do is get in the car, put the key in the accessory position just before it starts, roll the window down and close the door. Then raise your window up and hold it in that position till you hear a small tick, happens after about 3 or 4 seconds on my car and presto! the window should drop when door pull is used. Repeat for passenger window and your done. Hope this helps.
-Tony
Old Oct 1, 2010 | 08:23 AM
tanngo's Avatar
THANKS COUPEMAN.
DOES NOT WORK, when ascending or descending HOOD
the rear windows work fine.
Old Oct 1, 2010 | 09:10 AM
H20boy's Avatar
don't forget to cycle down and hold the button till a click, then up and when closed, remain held down till a click 4-5 seconds sounds about right.
Is that what you're asking tanngo? The front windows do not drop a 1/2 inch when the door handle is lifted? And it does not seal back to the roof when closed?
Old Oct 1, 2010 | 09:31 AM
tanngo's Avatar
h2oboy. hello.
do not drop when operating roof, sorry for language
Old Oct 1, 2010 | 09:56 AM
SeismicGuy's Avatar
I think what he is saying is that the windows are supposed to open when you hit the roof-down button and this is not happening.
Doug
Old Oct 1, 2010 | 10:01 AM
KevinW's Avatar
My front windows don't go down either when I raise and lower the top, just the rear windows. If you look closely at my signature pic you can see that the front windows are up but the rear windows are down. I believe that is the way its supposed to work. Anyone else want to verify that?
Old Oct 1, 2010 | 10:24 AM
SeismicGuy's Avatar
Kevin--you are correct. I believe it is the rear windows that first roll down, then the top goes down, then if you keep the button pressed I think the front windows finally roll down.
Doug
Old Oct 1, 2010 | 10:33 AM
tanngo's Avatar
perfect interpretation, I work as a kevinw. gracias
is normal ???
thanks seismicguy for interpretation .
Old Oct 1, 2010 | 11:52 AM
H20boy's Avatar
My front windows do not go down with the roof switch, even after the top finishes retracting.
Old Oct 1, 2010 | 12:02 PM
KevinW's Avatar
I'd run out and test mine to see if I hold down the switch what will happen, but its in the shop getting new double din Kenwood w/ Nav, bluetooth, DVD player, HD tuner, and rear view camera installed. I'll post pics on that this weekend. I'll test the windows when I get it back.
Old Oct 1, 2010 | 03:42 PM
coupeman's Avatar
Oops tanngo, I get what the problem is now. Sorry I can't help in the convertible area as I have a coupe. I'm sure you will find an answer on this forum though, its a great group and resource! Good luck and if I learn anything that might help, I'll post it for you.
-Tony
Old Oct 1, 2010 | 04:49 PM
tanngo's Avatar
thanks tony, positive summary, performance seems right.
Old Oct 1, 2010 | 07:58 PM
WhiteXKR's Avatar
On my 2001 XKR, the front windows do not go down when the interior switch is used to open the convertible top, however, the front windows do go down when the driver side door lock is used to open the convertible top from the outside with the key.
Old Oct 1, 2010 | 08:22 PM
tanngo's Avatar
holla, I never go down the front windows ,in my xkr 2001
johnnie ryall
Oct 19, 2015 09:44 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
JagCad
Sep 5, 2015 07:23 PM
niner nellie
Sep 1, 2015 10:53 PM
