XKR Excessive current draw
Old Jun 29, 2012 | 10:46 PM
Seakiwi's Avatar
Default XKR Excessive current draw
Hi everyone,
New to this site and looking for a little help.
I have a 2004 XKR coupe that is pulling down the battery with a current draw that we are having trouble finding.
The current draw should be 30 ma with everything turned off, however the actual draw is 200 ma which is killing the battery in no time.
I have tried a couple of service agents here in New Zealand (including the official NZ agents) but they have not been able to identify what is causing the problem. I currently have the car in the hands of a recommended auto electrician who has confirmed the above measurements and also that the current draw continues at 200ma even with every fuse removed from the vehicle. He is about to start stripping out the dash etc to get to the wiring for further testing.
Anyone seen an issue like this before or have any idea where we should be starting to look now?
I have owned the car for three years and initially it would flatten the battery to the point of not starting in 7 or 8 days. After 12 months I replaced the original battery but 12 months later was still experiencing the same level of discharge so have been using a battery charger to keep the battery up during periods of no use. The situation has now deteriorated to the point where the battery charger needs to be connected every night or the car won't start the next day, and it is doing my head in.
Absolutely love the car and need to get this issue resolved, preferably without disassembling the whole wiring loom!
Thanks in advance!
Old Jun 30, 2012 | 03:55 AM
steveinfrance's Avatar
There are a number of threads on this.
Without any offence - have you locked the car and waited 40 minutes ?
The computer doesn't shut down unless the car is locked + security armed.
Old Jun 30, 2012 | 05:10 AM
Seakiwi's Avatar
No offence taken, I should have been clearer.
Yes, locked, and as you say after 40 mins the draw drops to 30ma but with in 2 hours it has increased to 200ma.
Sorry if there are other threads, did a search and checked the last half dozen pages of threads in this forum.
Old Jun 30, 2012 | 05:34 AM
Obviously somethings waking up that shouldn't be.I don't see how that could be a harness fault if the drain drops to the correct value then goes up.
I've not heard of this fault
https://www.jaguarforums.com/forum/x...rain-xk8-6985/
before but it wouldn't hurt to turn the wipers off 'Auto' if they are on it.
I know it's a bit like the computer support line but have you tried a hard reset JIC?
If not the JTIS advice is to use a clamp type ammeter on the various feed lines rather than pulling fuses.
BTW our American cousins will be waking up soon (terribly late risers) and , assuming they've got some power since most of the US seems to be suffering a Lucas moment, they'll almost certainly have something useful to say.
Old Jun 30, 2012 | 07:12 AM
Steve8's Avatar
Yes, we're waking up. But I'll need another cup of coffee to figure out how Seakiwi gets such a high draw, our any draw, with all the fuses pulled
Perhaps a charging issue rather than quiescent draw?
Steve
Old Jun 30, 2012 | 07:28 AM
Seakiwi's Avatar
have tried with both auto wipers and auto headlights off and problem still happens.
haven't tried the -ve to +ve terminal hard reset
all suggestions appreciated!
Old Jun 30, 2012 | 08:29 AM
Steve
Leaky alternator/voltage regulator ? I can't fit that in with the drop to 30mA before it goes up again.
Most odd.
A hard reset can't hurt JIC a module has got its head on backwards.
Old Jun 30, 2012 | 09:03 AM
ccfulton's Avatar
Perhaps a long shot but could it be a faulty temp sensor?
The 4.2 has a computer controlled cooling fan and it could be that as the car cools it gets an errant signal that wakes up the control but not such that it turns on the fan.
Old Jun 30, 2012 | 12:11 PM
BobF's Avatar
Check the security and locking module for a spurious activation, this could cause the additional current load. It must be kept active (30 ma?) to receive the keyfob signal and unlock the car.
Old Jun 30, 2012 | 03:01 PM
WhiteXKR's Avatar
Check the little 'door' in the opening of the ignition lock. If it is stuck open, the car will never go to sleep thinking there is a key in the ignition, even if the key is in the off position.
Old Jun 30, 2012 | 03:56 PM
Seakiwi's Avatar
9 am Sunday morning here now, so will pass these suggestions on to the auto electrician tomorrow morning, he has the car at the moment so can't check them out myself. I ned to check with him that it is still exhibiting the drop to 30 ma then increase to 200 ma after a couple of hours as this was the report from the previous tech who tried to diagnose it.
As I said before, all suggestions greatfully accepted, been without the car for 4 days now and .... well..... I miss her!
Old Jun 30, 2012 | 04:04 PM
Seakiwi's Avatar
I hate it when i can't edit my post for spelling errors!
Old Jun 30, 2012 | 05:13 PM
A post in the new members section could remedy that. :-)
kj07xk
Dec 18, 2025 10:56 AM
Sambo21
Nov 19, 2015 03:55 PM
Matei Dima
Oct 8, 2015 11:45 AM
Rochester
Sep 14, 2015 07:58 PM
tvholden
Sep 12, 2015 11:13 AM
