P1582 and P1549
P1582 and P1549
Hi All,
This is from a 2005 S Type 2.5 with 6 speed transmission.
I went to a friend workshop over the weekend and he was testing his new tools and we pull out two error codes from my S Type - P1582 and P1549. We tried to clear them but could not do so. So this morning I contacted the local Jaguar Service center for an appointment but was told that the electronic technician is away for a week (talk about poor service ) and there is no one else. I need to travel to my home town and the trip is going to be heavy traffic and probably will take me 8 hours and just wondering if it is okay to travel with the codes as I don't find anything wrong with the car engine.
Any advise is highly appreciated and thanks to all.
P1582 is special in some way. You don't need to clear it any time soon (or, I suppose, at all). As the wording shows, it's about data being logged not a fault. (But a fault will have led to the storing.)
I think each engine bank has a VIS aka IMT. If P1549 won't clear it likely means the fault is solid (not intermittent) so it should be easy to find and fix.
I reckon the tech guy's entitled to a holiday like anyone else, btw.
I'm not sure there would be any harmful outcome of not fixing the IMT fault soon. Maybe one/some of: lower power, poorer fuel economy, increased emissions. (Eventually, perhaps cat damage?)
I expect google will get you info about VIS (aka IMT) but I think the basic idea is to change the incoming air path to help with fuel/air mixing.
P1582 is the EDR (engine data recorder) and CANNOT be cleared with an OBDII diagnostic scanner. You can ignore it or download the 30 some-odd frames of data and/or read/print/clear the information.
PDU,WDS,IDS is the way to scan/clear the data.
The EVENT was triggered and recorded.
Here is a TSB from the X-Type and is the same for all ECM logged faults.
bob gauff
bob gauff
I do have a JTIS manual, unfortunately, I upgraded my PC (much better working on electronics :-)) and I find my JTIS disk is heavily scratched. Last night I looked around, disconnecting and reconnecting, but there are several that sit under a plastic Jaguar shield.
If someone could pint me in the direction to look, I would be most appreciative.
Received 6,253 Likes
Look at the workshop manual / codes PDF!
P1582 is "flight" recorder data. Read the info - free to download!
It does not have anything in itself to do with TPS.
You have some fault that leads to P1582. Find that fault, then fix it.
Might be as simple as bad power.
If you want to decode P1582 get a cheap Mongoose-type tool but ONLY use it to read data.
And PLEASE go to the CORRECT forum!!!!
Maybe, this subforum is correct forum.
My 2004 Jaguar X-type 2.5 (petrol, V6, classic, AWD, saloon) already passed 130000 miles.
Abour 8 monts, I have problem with "yellow" indicator light on control panel. Computer shows fault: P1582.
I taught I need to replace TBS (or just sensor Denso 198500-3300). But seems, that is different fault, meaybe easier to solve than TPS.
I do not know what does mean "VIS", and "IMT".
Please, if you can explain.
NinoGrimace
09-09-2015 09:38 AM
NinoGrimace
08-26-2015 05:15 AM
