restore wood trim
Old Aug 19, 2009 | 12:30 AM
Jean-Karim's Avatar
Default restore wood trim
Hi all!
I have a 2001 Jaguar XJR and the wood trims are fading in many places due to the plastic covering the trims fading out with time. Did someone try those lens or plastic renovators to restore the faded wood trims? Results?
Thank you!
http://www.autogeek.net/lc-plastic-pro-kit.html
Old Aug 19, 2009 | 06:11 AM
Hey there JK....sorry I can't help, but hopefully someone else will jump in here.
Failing that, have you tried asking the question in the XJ section? You may find better responses there. Just a thought......
All the best
Old Aug 19, 2009 | 06:46 AM
rothwell's Avatar
Try using 3M Scratch Remover. I had a scratch on the ash tray wood and it took it out nicely. I noticed then that it does a good job polishing the overall plastic too. Finally I used Meguiar's Swirl Remover for good measure and the piece looked like glass when I was done. About $25 bucks for the polishes.
If that does not work, my dealer had to send out a cracked piece to have it recoated. I could get the name of the place that did it (in CA I think).
Old Aug 19, 2009 | 10:56 AM
H20boy's Avatar
roth, california is correct, all dealers are sending wood to be refinished out there somewhere. The name has been tossed out there a time or two over the last couple years, I remember contributing to the thread myself. However, the actual post eludes me. Perhaps a search will turn up the name. They do outstanding work, but it does take a few weeks to return.
Old Aug 19, 2009 | 11:44 AM
Jean-Karim's Avatar
Hi all!
Thank you for infos, and how much would cost those kinds of service??
Old Aug 19, 2009 | 01:02 PM
H20boy's Avatar
Gonna take a stab at this, though not sure my number is correct. My little window switch from the door had to be sent off, and I 'think' it was around $75. You do the math vs square inches of wood to be repaired.
Old Aug 20, 2009 | 04:12 PM
hlgeorge's Avatar
William Rau is one of the best in CA. Not cheap, but good.
Old Oct 27, 2009 | 08:18 AM
johnsjag's Avatar
Give these guys a look. They will deal with you directly and you can avoid whatever cost the dealers are adding on. I'm going to have my rear picnic trays redone. I spoke with you owner and he was very nice to work with.
http://britishautowood.com
Old Oct 27, 2009 | 11:25 AM
H20boy's Avatar
Good link to another refinisher John. Thanks!
Old Oct 28, 2009 | 11:08 AM
m0t0rm0uth's Avatar
Get in touch with XKs Unlimited (xks.com), also. They're in northern CA, and apparently they know who does a lot of warranty work for Jaguar.
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
