E type ( XK-E ) 1961 - 1975
Tecumseh HG500 AC Clutch Coil
Old Jan 9, 2023 | 02:38 PM
LKEtype's Avatar
Default Tecumseh HG500 AC Clutch Coil
Looking to get my ac working, tldr the ac clutch coil wire is gone. I believe the compressor is fine based on what the previous owner told me but for the life of me I can’t find anywhere that sells just the coil. Does anyone know of an alternate or shared part # that might work? It’s the Tecumseh HG500 compressor. Thanks!
Old Jan 10, 2023 | 07:08 AM
pragmatic's Avatar
Not sure which one but here is a start
https://www.summitracing.com/search/.../york-tecumseh
Old Jan 10, 2023 | 05:10 PM
Bob_S's Avatar
You may want to try a small tractor shop or small engine shop. A lot of the lawn/garden tractors use simular clutch coils. Take the clutch & coil with you so they can match it up.
Old Jan 10, 2023 | 10:00 PM
LKEtype's Avatar
Thx I figured I’d ask here before I take it apart and start trying to figure out if I can find a match. Also looking if a used one might be had.
Old Jan 11, 2023 | 10:51 AM
Coventry Foundation's Avatar
The E type used a special clutch which mounted with internal bolts (3 of the 6 that hold the front seal. They did this as the normal external bosses for the coil were machined off for the E type for fit. If your compressor has the 4 holes on the tabs for the clutch it is incorrect and will not fit well in the space. The Tractor parts supply is an excellent starting point.
Old Jan 11, 2023 | 11:33 AM
Just for clarity we pulled this rather rare document from the files.. Note the drilled and tapped holes on the 4 tabs. Real E type HG500s have only a small amount of the tabs left and they were not drilled or taped. The cases were machined at an early point. Also note in the parts list no clutch or flywheel is listed. We are not sure but it is possible the coil and flywheel were sourced elsewhere but we have no data on that.
File Type: zip
Old Jan 11, 2023 | 06:10 PM
LKEtype's Avatar
Thx for the detailed info. I had read the mounting was special for etype which is why you couldnt interchange with the hg500 found on VWs. I found a used clutch on eBay that passed the ohm test so once I receive it I have my fingers crossed that it will work.
Old Jan 11, 2023 | 10:44 PM
Bob_S's Avatar
I love that CF goes the extra mile to help others.
Old Jan 12, 2023 | 06:52 AM
George Camp's Avatar
LKE the normal issues are a worn friction surface or weak springs on the clutch. Most folks are not aware there were small rubber buffers stuffed between the clutch circles to stop the slapping noise on engagement and damp the springs a bit. Best of luck.
Old Jan 12, 2023 | 07:39 AM
Bob_S's Avatar
If I remember correctly, the air gap for the clutch should be ~0.020 of an inch. i.e. between the clutch plate and drive plate with the power to the coil disconnected.
jmurraywv
Aug 25, 2021 12:27 AM
Fellows
Feb 28, 2021 08:05 AM
scottatl
Aug 10, 2019 09:57 AM
jagdayn
Jul 24, 2012 12:49 PM
lazerbrains
Dec 6, 2010 10:41 PM
