F-Pace (X761) / C-X17 2016 - Onwards
BCM Module
Old Apr 13, 2022 | 01:25 PM
F-Pace33's Avatar
Default BCM Module
Hello
Anyone coulp tell me where is located the BCM module on th 2017 F-Pace S Model?
Thanks!
Old Apr 13, 2022 | 01:52 PM
Welcome to the forums F-Pace33,
On my 2017 25t, it's behind the LH Cowl Trim and I'd expect this to be the same on other variants:
It has 5 connectors and is secured by 2 nuts:
Other than admiring it, there's not much can be done without JLR Pathfinder diagnostics.
Old Apr 13, 2022 | 02:01 PM
F-Pace33's Avatar
thanks,. Will try to check the contact connectors defore going to the dealer.
Old Apr 13, 2022 | 05:09 PM
What is the problem with the vehicle?
Old Apr 13, 2022 | 08:07 PM
F-Pace33's Avatar
The headlamp,( adaptative led light) passenger side , the day light, ( long stript led ) first was intermittent , now seems permanently off , I have two DTC codes B103D-87 and B1D01-92, I have connected to the driver side and working good, Ther is a different voltage from two pins in each connector socket compare to the driver side. I will have to continue the trouble shooting or bring it to the dealer $$ Thanks for your help!
Old Apr 14, 2022 | 02:40 AM
You have done the same troubleshooting sequence I'd have tried which is headlamp substitution L to R to check and eliminate component fault.
The Workshop Manual DTC listing is not very helpful for the two codes. Here's the extract:
Unfortunately, when it comes to diagnostic equipment, the old Jaguar SDD doesn't cover F-PACE and JLR Pathfinder is required.
Old Apr 20, 2022 | 05:32 PM
F-Pace33's Avatar
Hello, you are wright, I've tried to check for any loose connectors, but, it's too complicated to regonize any wire and read voltage,,, next step Garage
Old Apr 22, 2022 | 02:33 AM
Make sure they eliminate harness faults before jumping to headlamp replacement. Your L to R test substitution strongly suggests internal failure is not the problem.
schuess100
Oct 19, 2022 04:37 AM
Roc3207
Sep 11, 2017 05:17 PM
Del Boy
Apr 19, 2014 06:21 PM
arthurdaley
Jan 3, 2013 11:04 AM
