02 Sensor Help 2016 F Type R United States
Old May 19, 2022 | 02:30 PM
jlalli2010's Avatar
Default 02 Sensor Help 2016 F Type R United States
Hello All,
I was driving home and my check engine light came on, long story short I used my odb2 and it says the following:
02 Sensor Delayed Response - Rich to lean Bank 2 Sensor 2
I called around and everyone is quoting between 2-400 for the part and another 3-400 for labor. Has anyone had any issues with something like this and had success fixing it on their own? I saw some forums and links but they are generally dead when it comes to finding the part etc. I know Bosch makes parts for it as well. Where would this sensor be located and do you guys think this could be fixed fairly easily? I am fairly handy but I just didn't want to pay more than I needed to but I also didn't want to make anything worse. Any and all advice would be appreciate thank you!
Old May 19, 2022 | 02:35 PM
supersportmtl's Avatar
Originally Posted by jlalli2010
Hello All,
Hey brother,
Very simply a faulty O2 sensor. They are under an extended warranty with Jaguar USA. So go into your local dealership for a free replacement!
Enjoy!
Old May 19, 2022 | 02:37 PM
jlalli2010's Avatar
Hello!
Really? I literally just called the dealership in Indianapolis and they quoted me all sorts of crazyness. If so that would be amazing.
Old May 19, 2022 | 02:39 PM
Yea well they have no clue what they are talking about! I had it replaced on my Stage 2 F-Type free of charge. So either tell them to inform themselves or go to another dealership that knows their product.
Old May 19, 2022 | 02:42 PM
winstonsalemncxk's Avatar
I also had an O2 sensor replaced until warranty even though the CPO had expired. Should be covered since it is a federally-mandated emissions component. Can't remember if it is extended to 8 or 10 years.
Old May 19, 2022 | 02:44 PM
jlalli2010's Avatar
That would be amazing, thank you! I will update you guys. Only certified/official Jaguar dealerships will take care of this correct?
Old May 19, 2022 | 03:07 PM
scm's Avatar
scm
I thought it was extended to 15 years in the US? But not, of course, in the UK.
Old May 19, 2022 | 03:28 PM
sov211's Avatar
The warranty on O2 sensors in Canada by JLR Canada was extended to 15 years from the in-service date. Obviously, independent service shops do not have access to the JLR warranty.
Old May 19, 2022 | 04:43 PM
kb58's Avatar
If you find that no one will fix it under warranty, it's not terribly hard to do yourself:
Old May 20, 2022 | 09:46 AM
zach05855's Avatar
Here is the letter
https://www.jaguarforums.com/forum/f...-miles-244795/
Old Jun 23, 2022 | 09:00 AM
jlalli2010's Avatar
Default Driving Limitations?
Hello All,
So I have an appointment scheduled in a couple weeks for them to factory replace the sensor. I really have only put 10 miles on the car since the light came on. How much (if at all) can I drive the car with this sensor being faulty? I know 02 sensors aren't the biggest deal but I didn't want to go zip around and in term cause any other issues. If I can drive it, do I need to avoid using dynamic/sport mode or keep the exhausts closed etc? Or is it possible to use it full power without any concern?
Old Jun 26, 2022 | 10:14 AM
clubairth1's Avatar
Community Influencer
I drove my XJ several weeks with the light on while waiting for the part to come in. I don't think you will have any problems.
It was only in the $60-$80 range and it was just simpler for me to change it. As posted above it's very easy and another recommendation is since your in there I changed both of them out.
Old Jun 26, 2022 | 07:53 PM
Unhingd's Avatar
No harm to driving with a bad O2 sensor. Its sole purpose is to trigger the warning light in the event something truly is wrong. (Bad cat or fuel mixture)
Old Sep 20, 2022 | 07:20 PM
pjr300's Avatar
Ugh... the ODBC light came on yesterday and today i started to misfire. Hoping to nurse it to the dealership tomorrow. Got a tester and it returned multiple error codes related to sensor and misfire.
Old Oct 13, 2022 | 09:39 PM
pjr300's Avatar
Repair completed today...took two trips as the sensor was not in stock. No fee... however, the "might as well get an oil change while I'm here" was a bad idea, as their price has skyrocketed to $314 for that task.
Old Oct 14, 2022 | 09:06 PM
Doc Oc's Avatar
$314 for a job that can be done in 20 min without tools? That's ridiculous. Buy yourself a Mityvac for a third of that and never pay those thieves again. It's the easiest oil change you'll ever find.
slipp3h
Aug 23, 2023 01:44 AM
maxiedaniels
Nov 27, 2020 08:39 PM
93greenconv
Feb 9, 2015 12:43 PM
StevenUSAnh
Nov 23, 2013 11:21 AM
daddyo007
May 5, 2012 08:05 AM
