2017 F-Type Purchased Last Friday-Fuel Question
Old May 6, 2024 | 01:45 PM
RootBeerGMT's Avatar
Default 2017 F-Type Purchased Last Friday-Fuel Question
Hello:
Last week we closed on a 2017 FTYPE Premium with 19k miles.
Went to put gas in it today when it was at 3/8th of a tank.
I filled it to the brim, but it still registers 3/8.
Thoughts?
Old May 6, 2024 | 01:48 PM
WhiteTardis's Avatar
its possible you may have a stuck fuel level sender. I've had that happen to me on some older cars; I dumped a bottle of Techron for 2 fillups and the sender started working again.
Old May 6, 2024 | 02:17 PM
DJS's Avatar
DJS
My sender hasn’t worked right for a couple of years, but it registers full down to around 1/2 tank. Are you sure you filled it, and the pump didn’t shut off prematurely? (That’s a separate possible issue.)
Old May 6, 2024 | 02:21 PM
sov211's Avatar
And as this car is new to you, I advise you most strongly to charge the battery fully. You would not believe the number of seemingly unrelated issues that comedown solely to one thing: a battery not fully charged and/or a battery reaching the end of its service life.
Miraculously, charging the battery cures instantly 98% of these issues…and it can be anything: touchscreen, seats, windows, multiple warning lights and yes, possibly the fuel level.
Battery first!
Old May 6, 2024 | 04:02 PM
Valerie Stabenow's Avatar
I have a 2017 Premium, but 6 speed. Just today I filled it, or thought I did, but the gauge showed only 3/4. Dollar wise it looked like it was full These cars have historically had issues with tripping the gas pump handle due to 'blow back from the gas going in the tank. If you hold the trigger to put the gas in and not just use the lock, you may be able to get more in. Sometimes that gas blow back has shut off the pump a few times before I get the nozzle inserted in such a way to get the gas going in peacefully. Here's a link to more Forum discussion:
https://www.jaguarforums.com/forum/f...l-tank-246513/
Old May 7, 2024 | 01:31 AM
Actually, it over filled.
Drove it home and it still stuck at 3/8ths.
The drive home was around 40 miles.
Old May 7, 2024 | 01:33 AM
That seems like a reasonable place to start. Planning on taking it back to dealer Wednesday to address a few minor items. Gas door also doesn’t open when you push it. Have to use a credit card in the crack to pop it open.
Old May 7, 2024 | 01:34 AM
Our prior XF would do that as would my last Maserati, which is super annoying
Old May 7, 2024 | 08:02 AM
Carbuff2's Avatar
3/8 of a tank?
I HATED fractions, since grade school!
Old May 7, 2024 | 09:21 AM
Dwight Frye's Avatar
I owned a Nissan 370Z and a wonky fuel gauge was a known issue and regular topic on the discussion forum for that model. The cure was to add some Marvel Mystery Oil in the recommended dosage to the fuel tank. Apparently the MMO acted as a mild solvent and freed up the floats or fuel level sensor by the time the tank was about empty again. After that I could go 4 or 5 tanks full with the gauge acting normally and then once again the gauge wouldn't read full. Another treatment of MMO fixed it. It was like that the whole time I owned the car.
So along with some Techron in the tank, you might try some MMO. It is fairly inexpensive. Follow the dosage instructions of the label.
Old May 7, 2024 | 10:01 AM
clubairth1's Avatar
Community Influencer
Yes a fuel cleaner with high levels of PEA can sometimes free up a fuel sender. I also use Techron once in a while.
These guys talk about it if you want some background?
PEA Fuel Additive
Old May 7, 2024 | 10:57 AM
CJSJAG's Avatar
I suspect it is somehow related to so few miles being driven.
Probably means old fuel sits in the tank for extended periods and gums thing up.
I assume your car has no warranty?
Old May 8, 2024 | 02:00 AM
Actually, I paid through the nose for the extended warranty. So, it’s supposed to go back today and I guess we will see how it shakes out. They also have a blue R dynamic which is probably the one I should have bought. It had a far better interior. That being said, I think I like these in white more than any other color which is not something I can say about most cars.
Old May 8, 2024 | 05:25 AM
CJSJAG's Avatar
Glad you bought the coverage. Hope all goes well.
Old May 9, 2024 | 07:01 PM
Old May 10, 2024 | 08:15 AM
Default ooohh NICE!
What a great exterior color and comb with interior... what colors are those?
Old May 10, 2024 | 08:32 AM
CJSJAG's Avatar
Nice Rolex!!
Did that come with the car?
Zeot
Oct 20, 2024 04:59 AM
Dudeman
May 18, 2023 11:20 AM
Snackalac
Nov 9, 2021 05:38 PM
Capt. Obvious
Sep 7, 2021 02:10 PM
WhiteTardis
Feb 26, 2021 03:35 PM
