F43 on the first few model years provides power to the active exhaust vacuum pump, which was deleted in later years. I have a remote relay which defeats this fuse, so I have either normal active exhaust, or valves open 100% of the time.
Same situation here both fuses 15 and 43 on MY 17 R awd…F15 states “active exhaust valve” and fuse 43 states “active exhaust”…. Which one to remove? Thx
Try both in various combinations and see what it does!
Welcome to the Jaguar Forums! It's great to have you with us.
It's always helpful to state the year, model and engine details of your Jaguar since wiring and other details can vary from year to year. A good way to do this is to visit your User Control Panel and Edit Your Signature to add this information so it shows up in all of your posts.
You may be able to subscribe to the factory service documents, including the wiring schematics, at eautorepair.net (Mitchell1) or alldata.com, which should answer your questions about which circuits the various fuses serve.
Another source is Jaguar TOPIx, though it can be more challenging to use:
@jazzyfingers2 Curious- did you remove one fuse at a time or both fuses at the same time? How did it go? I too seem to have both fuses 15 and 43…thx pls let me know your experiences!
Fuse 15 is the one on the 2020R for the valves. I would start there.
Where is the "exhaust gas solenoid valve" located in the system?
If it's the same values in the rear silencer, then with the fuse removed, how is there any power going to it to burn it out?
Defintely need to understand it a little more before considering.
Yeah man, this new info is ruining my glorious fuse 15 life…lol
Again, not necessarily trying to dismiss the info, but at the same time things do get said some times that may or may not be fully correct. These 4 people that had problems, is it for sure related to fuse 15? With the information I have to this point I’m not ready to jump fully in the pool and say yes.
I’m not truly knowledgeable about exhaust systems, but my first reaction is that it sounds a bit strange.
I took it to mean this other valve, or valves, is in the PPF/OPF unit itself?
