Any hints for connecting an ipod?
Old Jul 10, 2015 | 10:17 PM
Unhingd's Avatar
Question Any hints for connecting an ipod?
I plugged the ipod into the orange glowing USB port. It displays "do not disconnect" and the Jag screen says "please connect ipod"
Old Jul 10, 2015 | 10:42 PM
Foosh's Avatar
Never tried it and don't have any idea where my 2-3 remaining iPods are any more. I only Bluetooth stream from my iPhone, but try this:
Old Jul 10, 2015 | 11:04 PM
Unhingd's Avatar
The menus, symbols and soft button names are now a bit changed from this video, but the levels are the same. I get to the point where I select the ipod and I get the results as reported above. I wonder if it has to be a certain generation and above ipod. Mine's 11 years old. First time I've seen it since I bought it. Dug it out of the glovebox of my old MINI where it's been playing the entire time.
Old Jul 10, 2015 | 11:20 PM
Foosh's Avatar
Yes, the old ones may not be compatible.
Old Jul 11, 2015 | 05:13 AM
DuhCar's Avatar
I have an old iPod from around 2006 and it doesn't work. I have a newer iPod Touch from 2008 and it does work. And use the USB port closest to the passenger side.
Old Jul 11, 2015 | 05:29 AM
Unhingd's Avatar
Ok. The ipod dinosaur may explain the issue. The symbol next to the port on the driver side would indicate that to be the port to use. What happens when you try to use that one?
Old Jul 11, 2015 | 06:12 AM
DuhCar's Avatar
Car goes into limp mode. (j/k)
I use the other one to plug in my iPhone. I can t remember why now, but had to settle on this methodology. Perhaps others can chime in.....
Old Oct 7, 2020 | 02:56 PM
adityab's Avatar
Plowing old soil here. Is there a way to play music via the usb cord from an iPhone? My MY16 seems to only play via Bluetooth. Thanks!
Old Oct 7, 2020 | 03:18 PM
DJS's Avatar
DJS
Yes, I do it on my ‘14. On my old nav system, I go into My Music, Sources, and select iPhone (or USB, DVD, etc.)
Old Oct 7, 2020 | 04:08 PM
adityab's Avatar
Thanks! For some reason that doesn't work on my MY16. It resorts to bluetooth.
Old Oct 7, 2020 | 04:28 PM
scm's Avatar
scm
Would turning BT off on the iPhone make any difference?
Old Oct 7, 2020 | 07:16 PM
Unhingd's Avatar
On the MY’16 connect the USB plug to the white port in the console (not the orange port). Then select iPod on the My Source screen. Music can be controlled from the center screen. Yes, disable BT on the iPhone.
Old Oct 8, 2020 | 09:18 AM
adityab's Avatar
Thank you! Unfortunately that's not working for my iPhone XR. Are you able to play Spotify that way by any chance?
Old Oct 8, 2020 | 03:11 PM
adityab's Avatar
Also, it's nuts that you have to disable bluetooth on your phone, and then presumably manually turn it back on if you receive a call while listening to music. JLR!
Old Oct 8, 2020 | 05:15 PM
Unhingd's Avatar
why don’t you want to play your music via BT? That resolves all the issues.
Old Oct 8, 2020 | 07:11 PM
adityab's Avatar
Nevermind - I uninstalled and reinstalled Spotify and now the wired connection works. Thanks Unhingd!
Old Oct 8, 2020 | 07:42 PM
Unhingd's Avatar
Old Oct 9, 2020 | 04:33 AM
DJS's Avatar
DJS
When I plug in my iPhone on my MY14, the nav system tells me that’s it disabling BT, so I don’t have to do anything else.
Old Oct 9, 2020 | 05:14 AM
takeapieandrun's Avatar
When my girlfriend plugged her iPhone in to charge on the 'media' USB port it stopped playback through my Android phone's bluetooth and said something to the effect of 'bluetooth not available while iPod plugged in'. We see where your loyalties lie Jaguar, lol.
Old Oct 18, 2020 | 07:05 PM
Gray Knight's Avatar
My iPod work perfect in my 2020 F type R . All I did was plug it into the usb port
Stuart S
Sep 1, 2024 04:01 PM
Andy6878
Jan 30, 2021 02:25 AM
Baltobernie
Sep 10, 2020 04:21 AM
8bit
Apr 1, 2018 04:36 PM
doctock993
Dec 16, 2010 05:10 AM
