Battery Venting
Old Jan 15, 2024 | 10:52 AM
Wayne Barron's Avatar
Default Battery Venting
Question - is the battery vented on a Jaguar F-Type? If so where is the vent? The battery is in the factory location in the boot, but I do not see where it's vented. Can anyone help? Picture would be great. Many thanks - Wayne
Is their a vent in the battery compartment?
Old Jan 15, 2024 | 11:26 AM
Valerie Stabenow's Avatar
Default Question about your 'boot'
I noticed you have sound deadener in your trunk area. Did you notice much/any improvement in sound level? I haven't noticed any noise coming from that area in the MY2017 coupe I have, but always interested in others' experiences.
Old Jan 15, 2024 | 11:36 AM
We are building a competition car audio system in the car. I have not driven the car yet, since it is still under construction. I am hoping all this sound deadening material we are putting in the car will help with all the road noise. More to come.
Old Jan 15, 2024 | 11:41 AM
DJS's Avatar
DJS
I see the red vent on the battery, is nothing connected to it?
Old Jan 15, 2024 | 12:34 PM
zach05855's Avatar
it is the red connector by the bottle for flat refill.
Old Jan 15, 2024 | 01:09 PM
scm's Avatar
scm
Do AGM batteries need venting?
Edit: Seems so ... https://batteryknowhow.com/do-agm-ba...nted-find-out/
Old Jan 15, 2024 | 02:12 PM
lizzardo's Avatar
As already noted, it's the little red elbow by the bottle of tire goo. I just looked at mine and see it connected to a tub that goes down to the floor, then heads towards the rear on the left side of the battery. I'd have to pull panels to see where it ends, but suspect behind the bumper.
Old Jan 16, 2024 | 07:12 AM
2018XF25T's Avatar
Have you check underneath the battery or could have been accidentally tucked on the side hidden between the frame and the battery.
Old Jan 16, 2024 | 08:34 AM
Carbuff2's Avatar
Here's a close-up of the battery vent. As mentioned, positioned on the front-center edge of the AGM battery, with a red right-angle fitting.
N Bath
XJ XJ12 ( X305 )
Dec 22, 2021 05:47 PM
Alan Wrench
May 29, 2020 08:55 PM
Vector
Oct 10, 2015 10:23 PM
blindside
Jun 28, 2015 08:55 AM
Kevin93940
Jan 11, 2015 01:26 AM
