Dead battery inside Key FOB ....
Old Feb 9, 2022 | 12:10 PM
Turko's Avatar
Default Dead battery inside Key FOB ....
Hi Guys,
my 2017 F Type R is in winter storage. I learned today, the battery is now dead. Battery must be replaced with a fresh battery.
Is this something I can do myself? Once the battery is replaced will the Key FOB need to be reprogramed? If... the dealer must get involved, approx how much do they charge for such a service to change and reprogram the Key FOB.
Thanks for your replies and information.
Rob
Old Feb 9, 2022 | 12:37 PM
Mahjik's Avatar
You can replace it yourself. Does not require reprogramming.
Old Feb 9, 2022 | 01:02 PM
Supersprint Sport Exhausts's Avatar
Default Great !
That's what I suspected but I wasn't 100% sure. I have the correct battery number. ( CR2032 ) so I'm good to go! Thank you for the verification.
Rob
Old Feb 9, 2022 | 01:14 PM
sov211's Avatar
[QUOTE=Turko;2494934]Hi Guys,
my 2017 F Type R is in winter storage. I learned today, the battery is now dead. Battery must be replaced with a fresh one.
Please note: your new battery will almost certainly NOT be fully charged at installation. Make sure that it is brought to full charge. Do not accept a statement such as “the battery tests GOOD”.
Old Feb 9, 2022 | 01:22 PM
DJS's Avatar
DJS
His key fob battery, not main battery. I think it's in the manual, but if you haven't opened the key fob before...
Slide off the metal part, revealing the emergency key.
Remove the key, and slide it into the slot. Pry apart the 2 halves of the clamshell.
Replace battery, and snap it back together.
Old Feb 9, 2022 | 02:02 PM
eeeeek's Avatar
FYI - If you need to replace one, you should replace the one in the other key, too. I remember it taking less than a minute.
Old Feb 9, 2022 | 02:18 PM
RGPV6S's Avatar
^^^This. The battery in my everyday FOB went dead so I switched to the back up. It went dead a few days later.
Old Feb 9, 2022 | 05:52 PM
Default Thank you to everyone .
Thank you for all the replies especially the instruction from member DJS.
Now I don't have to fumble with the key fob in my hand examining it and looking at how to pry it apart. Straight forward instructions easy enough to do. Thank you so much!
Old Feb 9, 2022 | 06:07 PM
Life And Projects By Austin YOUTUBE's Avatar
Originally Posted by Turko
Hi Guys,
Rob
I actually posted a video of this on my channel
Here ya go!
Adventurous x
Dec 20, 2021 08:32 AM
UKWyldcat
Aug 3, 2021 09:05 PM
Chuck Schexnayder
Jan 31, 2019 02:03 PM
stevef
Mar 2, 2009 11:44 AM
Jamey
May 9, 2008 03:40 PM
