engine part
Old Sep 10, 2017 | 10:50 AM
southeastautogroup's Avatar
Default engine part
Hi: have a 2016 f type v6 s awd conv. We need a connecting rod due to one rod being bent due to hydrolock. Car runs but has a knock. Have not been able to acquire this part from jaguar . Perhaps someone has an engine they are parting out or someone can tell us wht other jag models use the same engine . Any help would be great
Old Sep 10, 2017 | 11:46 AM
WhiteTardis's Avatar
I don't think internals are available separately. You'll need an entire engine assembly.
Old Sep 10, 2017 | 01:04 PM
RGPV6S's Avatar
Was the car in a flood?
Old Sep 10, 2017 | 02:29 PM
Unhingd's Avatar
The rod may still be good. It might just be a pounded out rod bearing. Even if it looks good, you'll need to Magnaflux the rod to make certain it's not cracked. Similarly you may have to do the same with the crank. Inspect the corresponding crank journal carefully. If it requires surfacing you'll need to use an undersized bearing. In all, it might be cheaper to go with a salvaged engine (~$10k).
Old Sep 10, 2017 | 05:18 PM
The car was driven into a large puddle water entered the intake
Old Sep 10, 2017 | 05:19 PM
car was driven into a large puddle and water entered the intake
Old Sep 10, 2017 | 05:24 PM
Would an engine from an xf s be the same and is it interchangeable . There are not many options available on used f type engines and do you know if the awd model uses a different block Thx for any help regards
Old Sep 10, 2017 | 05:25 PM
Cambo's Avatar
Have a look in the X250 XF subforum, guy called Dave was able to source crank, rods and bearings for a rebuild of his 5.0 he had access to internal engine parts through some back door contact.
Old Sep 12, 2017 | 07:00 AM
Unhingd's Avatar
https://www.pacificmotors.com/auto-p...-x152-2014-17/
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Miss Charlee
Oct 5, 2016 07:03 PM
dennysjag
Oct 1, 2016 03:59 PM
sjuraud
Aug 28, 2010 02:11 PM
