F-Type sloppy loose handling -Why?
Old Jul 31, 2019 | 05:45 PM
JagAston's Avatar
Exclamation F-Type sloppy loose handling -Why?
Need some help plz.... looking at a F-type 2015 v8 convertable only 7500kms... test drove but seems quite loose sloppy in its ride and handling.?
Feels like its done 75000kms in reality... is this normal with the model.?
... i have a new AM Vantage which is very tight. Is it unfair comparisons ?
Or is the Jag suspect ?
Old Jul 31, 2019 | 07:18 PM
OzXFR's Avatar
Mods - suggest move this one to the F-Type sub-forum.
Anyway, no this is not normal, the F-Type vert has a well earned reputation as one of the tighter and better handling verts because it was designed and built as a vert from the get go and not as a "chopped" sedan/coupe.
So something is wrong and my first suspect would be the tyres.
OEM fitment on all F-Type V8s has always been Pirelli P Zero and they have a terrible reputation on this forum for poor grip and handling, especially once they are a bit worn.
I would guess this car still has the original P Zeros on it and that may entirely explain the problem.
Also it's not uncommon for the F-Type to have way out of spec wheel alignment especially the front toe in, so that may be part of the problem.
Old Jul 31, 2019 | 10:13 PM
BruceTheQuail's Avatar
It might be this car, if it is in Sydney https://www.carsales.com.au/cars/det...16470962/?Cr=0
The tyres would be coming on 5 years old now, might have gone hard. It wouldnt be unusual for the back to step out though.
The ride shouldnt be wallowy at all, and the steering should be very direct and quite light. The ride should be pretty firm given the seats havent softened up but not jiggly except maybe in dynamic.
Old Jul 31, 2019 | 10:23 PM
JagAston's Avatar
spot on thanks - good research - best i test drive another one and i will then know.
Dont get me wrong beautiful car no disrespect to the jag brand
Old Jul 31, 2019 | 10:29 PM
JagAston's Avatar
thanks i love the jags and the look of them... hence want one...no disrespect intended.... new at this forum stuff..but thanks for the input
Old Jul 31, 2019 | 10:36 PM
No drama at all, enjoy the search! I considered going to Aston recently mainly for the noise and a manual V8 but it is hard to get out of the Jag!
Unhingd's Avatar
The steering on the F-Type is as tight as they come. Even crappy tires shouldn’t make the steering feel loose. Might be worn ball joints in the steering linkage but more likely an alignment issue. The car probably has a toe-out rather than a toe-in.
Old Aug 1, 2019 | 07:10 AM
Carbuff2's Avatar
Owners have reported 'sloppy' handling if the height-sensing parts of the suspension have come adrift.
I'd continue your search...
Old Aug 1, 2019 | 07:25 AM
JagAston's Avatar
much appreciated -love the model -will take your recommendation -the SVR looks good too.
Old Aug 1, 2019 | 08:11 AM
Mahjik's Avatar
A lot of feeling will be subjective, however, the best idea is to test drive a new F-Type even if you don't plan to buy it. Get a feeling for how one should feel so when you browse the used market you can spot issues easier. Good luck on your hunt!
Old Aug 1, 2019 | 09:09 AM
Tp10XKR's Avatar
Coming over from the GM line of sports cars (CTS-V, Corvette, and Camaro) and one XKR - which floated down the road, the F-Type is the firmest most accurate point and go steering I have experienced that is why I made the move .....well and the freaking exhaust !!!
Old Aug 2, 2019 | 08:51 PM
FType17's Avatar
I find that rather unusual. I would make sure that the tires are not overinflated (simple), next would be front end parts (ball joints etc.).
The handling of the F-Type is rather precise and firm.
jazzwineman
Sep 7, 2019 08:01 PM
VancouverXJ6
Feb 10, 2018 03:31 AM
hisport
Jun 26, 2016 08:14 AM
steve_k_xk
May 12, 2016 04:42 AM
Jagfix38
XJ40 ( XJ81 )
Nov 18, 2011 10:28 AM
