Has my coolant y pipe been upgraded?
Old Feb 16, 2026 | 03:02 PM
FTypeInTheSun's Avatar
Default Has my coolant y pipe been upgraded?
2016 S AWD. Not sure if I'm even looking at the right thing, but wondering if my coolant y pipe has been replaced/upgraded?
Old Feb 16, 2026 | 03:23 PM
cpq100's Avatar
Yes. You have the seamless plastic pipes. The originals were replaced.
Old Feb 16, 2026 | 03:25 PM
Oh wow! That's a really nice surprise! I had this car 3 months now and I'm super happy with it! The coolant y pipe was on my radar, but hopefully I can stop worrying about it for a while ( car has 49k miles ). Thanks for confirming! I know there's an even better option, the aluminum pipes, but this seems like a good start!
Old Feb 16, 2026 | 05:07 PM
Robtrt8's Avatar
Keep an eye out for leaks/low coolant in the reservoir. There are several other items that can go bad.
Old Feb 26, 2026 | 01:22 PM
wabuegel's Avatar
Default Rear coolant manifold.
There’s another coolant manifold at the rear of the engine “at least on my v6” that feeds the heater in the cabin. It’s also sandwiched plastic and is prone to fail. I sourced a metal replacement on line and installed it. It’s not to difficult although the wiring harness and symposer are in the way. This the first time I’ve posted photo I hope they help.
Old Feb 26, 2026 | 01:23 PM
wabuegel's Avatar
I believe the V8’s have only 2 bolts per side.
Old Feb 27, 2026 | 12:39 PM
rbr's Avatar
rbr
The above is correct, 2 bolts per side on the rear crossover for the v8. Also, while you have the new style front crossover, this is not your y-pipe, which is below the left side of the crossover and may or may not have been replaced, even if so is undoubtedly still plastic and still prone to brittleness issues.
Old Feb 27, 2026 | 12:43 PM
Robtrt8's Avatar
I was told the 3rd gen (2nd gen plastic) crossover pipe supposedly does not work with a Y pipe not matching it’s generation.
adent
Aug 7, 2025 12:47 PM
Lord_P
Feb 8, 2025 04:22 PM
jschimmels
Jan 6, 2025 10:45 AM
AbsoluteJaaaaaaag
Sep 12, 2024 03:27 AM
Mack74
Jul 26, 2024 09:28 AM
