Hood alignment shifted at high speeds
Old Mar 12, 2021 | 10:46 PM
Biofreak's Avatar
Default Hood alignment shifted at high speeds
Hoping someone has gone through this. I am on a road rally with my SVR.
on the first leg I got up to around 190mph. I started noticing that the hood seems to be catching wind and moving around so I slowed down and checked when we stopped.
the hood has shifted back into the door panels. And the gap it creates let’s in air which flexes the hood at speed...
and suggestions for roadside diy repairs? I’ve taped up the gaps to stop air from flowing in and causing any more shift but the hood is far enough back to rub on the doors when you open them.
Old Mar 12, 2021 | 11:17 PM
OzXFR's Avatar
The main things holding the hood in place are the four 16 mm bolts on each of the two front hinge plates, and they do allow some leeway for fore/aft adjustment.
So that is the first thing I would check - loosen off those eight bolts just a tad, push/pull the hood forward a tiny amount, then do them up good and tight.
Much easier with a helper than by yourself, don't ask how I know this!
Old Mar 13, 2021 | 06:44 AM
CJSJAG's Avatar
Where do you get to drive 190mph??
Old Mar 13, 2021 | 08:02 AM
cpq100's Avatar
Profile indicates OP is from South Africa.
Old Mar 13, 2021 | 08:16 AM
Biofreak's Avatar
Exactly there
We have loads of deserted roads out in the Country.
Old Mar 13, 2021 | 08:17 AM
scm's Avatar
scm
Originally Posted by Biofreak
Exactly there
And no speed limits? Or highway patrols?
Old Mar 13, 2021 | 08:22 AM
cpq100's Avatar
I just checked and saw South Africa uses the metric system. Might that 190 mph be 190 kmh?
Old Mar 13, 2021 | 08:23 AM
Biofreak's Avatar
It’s a vast quiet road without much policing...
as an update, my rally got even worse. I blew a CV or rear diff. Oil all over the rear with a rattling loose coupler.
Old Mar 13, 2021 | 08:24 AM
Biofreak's Avatar
305km/h
Scotlad
Mar 27, 2017 08:42 PM
Ubad2
Aug 3, 2016 10:40 AM
jaguar jon02
E type ( XK-E )
Nov 17, 2014 01:17 PM
quinnjere
Sep 2, 2014 10:08 PM
Mullion
19
Jun 15, 2014 07:43 AM
