Quick Question on 2016 - Can I jump the car from the front terminals?
Old Jun 11, 2022 | 01:31 PM
jlewis10's Avatar
Default Quick Question on 2016 - Can I jump the car from the front terminals?
Had a state inspection and had completely forgotten about the OBD drain issue. Came out 2 days later to a completely dead car, no trunk access of course. Connected trickle charger to the front terminals and it charged to 3.6 and would not charge further - and was still not enough for me to open the trunk.
Seems my trickle charger isn't strong enough (or the battery is shot, I'm not sure which). Can I safely try to jump the battery from the front terminals, hopefully enough to open the trunk and get proper battery access?
Old Jun 11, 2022 | 03:07 PM
19FRG's Avatar
yes, that's what they are there for.
Old Jun 11, 2022 | 04:56 PM
DJS's Avatar
DJS
Battery maintainers can’t charge a completely dead battery - they don’t turn on until they detect something like 5V. A battery that low has given up some (or all) of its life. An battery charger connected to the front jump points should allow you to open the trunk. But as mentioned, you can jump it from there too.
Old Jun 11, 2022 | 06:53 PM
Whatsnext's Avatar
I have a 2016 as well and if that is your original battery its time to go. I had to replace mine a few months back. And hook cables or a booster to the front points and it will allow you to pop the trunk and gain access.
Old Jun 12, 2022 | 12:00 AM
BritCars's Avatar
Trickle charger can't keep up with charing battery and overcoming the battery drain issue. You need to first disconnect the battery for 30s to reset the battery drain issue. Then connect trickle charger and it should charge it up after that. Give it 24 hours or so
Old Jun 12, 2022 | 10:17 AM
uncheel's Avatar
I'd suggest a blend of the good advice above. Disconnect the battery to reset. Try recharging again. And, shop for a new battery - you're due. Even if you get the current one working for now, you're on the clock. It's not that big an expense, and it's a pain when the battery fails. For reference, my MY17 battery was replaced a year ago under warranty by the dealer, and I replaced the original battery on the MY14, just to be safe (Costco/Interstate). And, if your trickle charger is an old-style unit, I suggest getting a CTEK with a reconditioning function. My F-Type probably doesn't sit still long enough to NEED one, but I got a space set of pigtails for it and the lawn tractor, so it's easy to move around. (And, the lawn tractor has been on the same battery for the last 7 years, so the claims about extending battery life are probably well-founded.)
Old Jun 12, 2022 | 12:30 PM
jlewis10's Avatar
Dumb question, sorry - but I can't open the trunk because the dead battery. How am I to disconnect the battery when I cannot access it?
Old Jun 12, 2022 | 12:36 PM
DJS's Avatar
DJS
If you have another car and jumper cables, connecting that cars battery to the front jump points should allow you to open the trunk.
jlewis10's Avatar
Yeah, I was hoping mostly to just get enough out of it for the rest of the season - I plan on picking up a replacement at Costco. Unfortunately I'm unable to access the battery to disconnect it since the trunk won't open - and saw on another post that someone attempted to jump the car from the front and caused big sparks, and it seemed like folks thought the front terminals were for a battery tender only. So I'll give it a jump to hopefully at least get the trunk open for now. Thanks for the advice!
Old Jun 12, 2022 | 12:37 PM
jlewis10's Avatar
Palm, meet forehead. Duh. Thanks.
dancemom
Mar 14, 2022 09:34 AM
inertian
Aug 4, 2021 10:51 AM
bobhoff
Sep 29, 2018 08:14 AM
Lommi
Jul 8, 2017 01:52 PM
Dpk2313
Mar 11, 2015 09:31 PM
