Sticky Button Fix
Old Feb 10, 2021 | 05:06 PM
ChuckTrish1's Avatar
Cool Sticky Button Fix
I recently purchased a new to me 2016 F-Type, Sticky buttons and plastic trim, I searched the internet and came across a story where someone suggested using Neutrogena Makeup Remover Wipes, figured I give it a go..... well surprisingly it worked. Let me first state this is not a fast tasking, rub with wipe, once area is wet, use a lint ffee cloth and continue wiping. Repeat many times and gentle force is needed. I ended up using my finger nail wrapped in the cloth to scratch it as well. Results, glue substance came off and surface is clean, smooth, and no damage.
hope this helps
Old Feb 10, 2021 | 05:46 PM
2004XJ8's Avatar
Yes one of the many ways to do this. I used guitar fret board conditioner by dunlop its is a lemon oil based product. Similar technique as well slow and steady I used a guitar pick to gently move the goo around and to pick it up.
one thing I would like to add different parts react differently to cleaning methods Th steering wheel bezel trim pieces are known for the finish to lift off when cleaning. You need to to be careful when doing certain pieces.
Old Feb 10, 2021 | 06:03 PM
I am actually needing to do the steering wheel bezel trim along the top, what do you suggest?
Old Feb 10, 2021 | 06:07 PM
Mahjik's Avatar
I'm not trying to be mean, but you should use the search function first to see if the same topic has been discussed. Most of the time, you'll find answers already in the forum rather than waiting for someone to respond. Here's a thread to review:
https://www.jaguarforums.com/forum/f...lastic-238719/
Old Feb 11, 2021 | 05:51 PM
2004XJ8's Avatar
I have found the search function to be a bit quirky and sometime even when the search text is specific it does too broad a list.
Old Feb 11, 2021 | 08:54 PM
Mahjik's Avatar
I've had zero issues with. That thread I linked took me 30 seconds.
Old Feb 11, 2021 | 11:34 PM
Me too
or maybe I need to try harder
Old Feb 12, 2021 | 08:13 AM
Craaaazzy's Avatar
use google for your searches...much better results. use your key words and specify the site you want searched like so:
"sticky button fix f-type site:jaguarforums.com"
nasa25
Jun 18, 2025 03:07 PM
OzXFR
Aug 16, 2023 08:47 PM
salukutinaveen
Jun 28, 2020 05:19 AM
HawaiiRealtor
Jun 1, 2018 01:48 PM
Bigvettefreak
Aug 24, 2015 08:29 PM
