Whine from the differential, shavings in the oil
Old Aug 15, 2020 | 07:38 AM
tkwesa's Avatar
Default Whine from the differential, shavings in the oil
The whine from the differential was getting worse, very noticeable on acceleration or deceleration, so did a quick oil change to see what's going on:
https://imgur.com/a/81kcArh
Plenty of fluid came out. Looks like it had been changed recently. About 53k miles on the car, no clue if the diff is original or not. I just bought her used, so no warranty. I am planning on continuing to drive it until the whine gets so bad I'm ready to fork over the cost of a new differential. Good idea or bad idea?
Old Aug 15, 2020 | 11:07 AM
SinF's Avatar
Differential lock up can be a mode of failure.
Old Aug 15, 2020 | 12:50 PM
madmax1911's Avatar
Was there any reduction in whine after you refilled with fresh fluid ?
Old Aug 15, 2020 | 06:43 PM
Cambo's Avatar
If the fluid was changed previously, do you have any receipts or documentation to show which fluid was used?
E-Diff needs a different fluid to the standard differentials. I know of three cars around here with E-Diffs where the wrong fluid was put in, two cases from independent garages, one case the dealer did it.
They used "genuine" fluid, but the wrong one...
E-Diff requires Castrol BOT-720, Jaguar p/n C2D3650 (this is also used in the V6S mechanical LSD)
Standard diff requires Castrol BOT-750B, Jaguar p/n C2D3653, replaced by C2P25272
If you put the BOT-750B in an E-Diff, it will be destroyed very quickly...
Old Aug 16, 2020 | 02:37 AM
tkwesa's Avatar
No reduction in whine after fluid change. I used Motul Gear 300 LS 75W90.
I don't have any of the documentation on the previous fluid changes, last owner "tossed" all the paperwork. Might be that he knew the rear was grenaded.
Old Aug 16, 2020 | 08:27 AM
SinF's Avatar
It is likely failed as a result of incorrect fluid.
Jaguar e-diff takes special fluid - Castrol BOT 720. See here for more details: https://www.jaguarforums.com/forum/x...-fluid-225273/
However, now that metal shavings came out, you at the very least need to flush it (e.g. do oil change few times or hook it to a machine to cycle oil) and put correct fluid to have a chance of it lasting.
Old Aug 17, 2020 | 03:03 AM
tkwesa's Avatar
I don't know what the previous owner used, as this is the first time I've changed the fluid and found the damage in this first oil change.
So Motul Gear 300 LS is not the right fluid?
Old Aug 17, 2020 | 06:34 AM
SinF's Avatar
I don't know. The OEM fluid has special additive for e-clutches.
Old Aug 17, 2020 | 07:01 AM
Unhingd's Avatar
it’s not specific to the e-clutch as it also applies to the mechanical clutch in the V6 LSD.
Old Aug 17, 2020 | 09:01 AM
SinF's Avatar
Since this is "mechanic in a bottle" attempt to make already-broken differential last a bit longer, I would attempt anti-wear additives such as ZDDP. It is used in metal-on-metal applications, I suspect some of it is going on inside your differential and this is why you are seeing metal in the oil. I am not sure if it will negatively impact e-clutch operation but it will protect gears.
Old Sep 15, 2020 | 05:21 AM
tkwesa's Avatar
After the whine continued to get worse and a terrible grinding noise started, I took her to the local dealer to get a new diff. They quoted me 3000 euro for the whole thing, which is a lot less than what I was expecting. Hope to have her back soon.
Old Sep 15, 2020 | 12:21 PM
2004XJ8's Avatar
When I had my diff fluid changed a month ago the dealer listed the fluid used as LR019727 . my car is a 2014 S V8 with E DIFF
Did they use the correct fluid?
Old Sep 15, 2020 | 02:30 PM
RGPV6S's Avatar
Was the correct fluid. Do a search for that part number its for Castrol BOT 720. This is for use in F-Type with E- Diff and LSD.
Old Sep 17, 2020 | 06:02 AM
tkwesa's Avatar
And 3700 euro final price, or about 4500 USD - I have a new rear differential.
I might do it myself next time
Old Sep 18, 2020 | 06:00 AM
2004XJ8's Avatar
Rimmer Bros list the fluid as such, this is what was listed as used on the service slip from my Jaguar dealer appears to be a Landrover part number LR019727.
Picture shows castrol packaging.
Amazon shows it packaged in Landrover packaging.
These guys don't make it easy to service your own car, when they can't or won't make it clear which correct fluids to use.
By the way I only use the fluids recommended by the manufacturer as there is a reason they recommend these.
https://rimmerbros.com/Item--i-LR019727
https://www.amazon.com/Land-Rover-Electronic-Differential-Discovery/dp/B07FMB5GHL/ref=asc_df_B07FMB5GHL/?tag=bingshoppinga-20&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4584070147492298&psc=1 https://www.amazon.com/Land-Rover-Electronic-Differential-Discovery/dp/B07FMB5GHL/ref=asc_df_B07FMB5GHL/?tag=bingshoppinga-20&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4584070147492298&psc=1
Old Sep 18, 2020 | 12:42 PM
Terrance39's Avatar
After my diff started whining, I drive it for months until it annoyed me enough to change it lol. When I first drained my original diff, only like half a quart of fluid came out. There was no wet spots anywhere for the diff to leak, so i still have no idea where the rest of the fluid went. That's probably why it overheated in the first place. Found a used diff from a 2016 on ebay. I replaced it, and refilled with redline 75-140 recommended by redline to help with better cooling. Been running it for over a year now and I beat on my car every chance I get, and she is fine. I also have another used diff sitting in my garage just in case lol. But nothing has alarmed me that it is going out.
Old Sep 24, 2020 | 02:58 AM
tkwesa's Avatar
You replaced it yourself? I looked into doing so but I didn't have the specialized tools like 204-477. How hard was it? Would you be willing to give a little write up?
Old Sep 24, 2020 | 06:53 AM
Terrance39's Avatar
No I didn't have the time to do it myself. I was on the toad traveling. So I let a friend of mines that has a shop do the work. If I was home I would have did it myself though. From what he said it was a pain in the *** because he had to lower the rear subframe etc.
Old Sep 25, 2020 | 12:31 PM
clubairth1's Avatar
Community Influencer
I changed the rear diff fluid in my 2014 XJR @42K miles.
Here is the thread with pictures. I used Redline 75W90 #57904.
XJR Rear Diff Fluid Change
Be sure and note the part number as Red Line has several very similar products.
But #57904 does meet the Castrol SAF Carbon mod.
Redline 75W90 Fluid Specs
Old Sep 25, 2020 | 06:10 PM
Unhingd's Avatar
Traveling by toad must be quite an experience.
