2000 XJR seat to work outside a Jaguar help
Old Jul 17, 2024 | 04:53 PM
guanshee's Avatar
Default 2000 XJR seat to work outside a Jaguar help
I have a 2000 XJR seat with the seat module LNC2160AD. I'm trying to transplant the seat to a 1968 Jaguar MK2. Is it possible to control the seat without a CAN system. Here are pics of the seat connectors and wiring.
Old Jul 17, 2024 | 08:37 PM
Thermo's Avatar
Veteran: Navy
guanshee, I have helped a few others do what you are looking at doing. I am on travel, so, give me a few days and I will look up what wires you need to put together to make the seat work in the other car. If you do some looking under seat wiring and my name, you might find some useful information and atleast give you a starting point. There should be 3 black wires that you will need to find. Those will be your grounds. By the way, do you know if the seat is a 10 way, 12 way, etc seat? Things vary a little with options like this.
Old Jul 17, 2024 | 09:09 PM
guanshee's Avatar
Thanks Thermo. I believe this is a 16-way seat. Here is a pic of the driver seat module connector diagram and I have all 3 plugs. As from the original picture, I'm not sure what the white connector plug represents and of its colored wires.
Old Jul 17, 2024 | 09:36 PM
Don B's Avatar
Hi guanshee,
You can download the wiring schematics for the 2000 X308 at this link, courtesy of our member Gus:
Jaguar X308 Electrical Guide 2000
See the section on Seat Systems.
Cheers,
Don
Old Jul 18, 2024 | 01:13 PM
guanshee's Avatar
I did have this guide which is where I pulled the connector diagram. Here is my recent update. I connected all the brown (N) color combination wires on both connectors SD1 and SD3 but still no response from the seat switch control. With the connectors connected to the seat module, I was able to get all the motors to respond with the exception of the lumbar pump, if I applied power (+) with a probe to pins 9 to 16 on the SD1 connector while connected to the seat module. I still need the motors to respond via the seat switch controls and am not sure why they are not responding.
Old Jul 18, 2024 | 03:09 PM
guanshee's Avatar
I got things working with the seat switch (seat movement, headrest, and lumbar pump). Here are the wiring spice connections to do while connectors are plugged into the seat module, which are simple:
  1. Connect the GU (Green/Light Blue) wire on the white plug which connects to the seat switch control to (+).
  2. Connect pin 5 (NR - Brown/Red) wire on the SD3 connector to (+).
  3. Connect the black wire from the white plug to (-) ground.
I hope this helps others. I've attached pics for reference.
Old Jul 18, 2024 | 03:36 PM
Thermo's Avatar
Veteran: Navy
Ok, having the above diagram, I am going to tell you how to wire this up.
The wires going to ground: Follow the pin numbers, do not worry so much about the wire colors as we have a drawing from a different vehicle and the wire colors may be different.
SD3 (white plug) Pin 1: Black wire wit ha pink stripe
SD3 Pin 2: Black wire - may need to follow this back a little bit as it appears to split and go to both chassis ground and the ground on the switch pack to hte side of the seat. Diagram is saying black, but the pictures are saying brown. Will have to look at whatever wire is in DS3 PIn 2 spot.
You need battery power to :
Sd5 PIN 9 (plug going to seat switch pack - green wire with a blue stripe
SD3 PIn 5 - Brown wire with a red stripe
If you need more info, let me know.
Old Jul 18, 2024 | 04:14 PM
guanshee's Avatar
Thermo,
Thanks for the quick reply. I did get it working as I noted in my previous post. Thanks for confirming the connections.
knares
Feb 21, 2024 07:53 PM
Donzi
Sep 5, 2017 03:53 PM
juha_teuvonnen
Jul 14, 2016 07:15 PM
xjrjag
Jul 2, 2015 04:59 AM
Donzi
Apr 1, 2011 09:53 AM
