Cloned dealer scan tool
Old May 24, 2013 | 12:12 AM
  #341
H20boy's Avatar
Just in case others are in need, I'm setting up a link to the 'older' mongoose drivers that I was forced to use with my SDD v130. The Pro didn't work with the clone, and the one on the disc wasn't stable either with newer SDD versions succeeding 128.
J2534 64-bit version J2534 32-bit version
Old May 24, 2013 | 11:01 PM
  #342
XJR Prototype's Avatar
This thread makes me want to buy a set-up already built and working correctly. Wow!
I did this with my old BMW and had all the goodies and programs for that car, fun stuff!.
I haven't needed a laptop for the Jag yet but it's now on the mod list!
Old May 28, 2013 | 06:54 AM
  #343
JagV8's Avatar
Originally Posted by wearlej
Well, just to add to the knowledge out there, grabbed a copy of 131.01 from Ebay, installed to a VirtualBox WinXPSP2 32bit vm. Grabbed a ""Mongoose"" from ebay (Spanish Seller, although parcel had UK stamps on it)
Plugged it into the car 2003MYS-Type, manually entered the VIN, It tried to launch the Legacy IDS, did nothing, the car has now decided it has, a Gearbox fault, DTS not available, Engine warning light, Restricted performance and a Handbrake fault, so simply plugging this thing in seems to have killed the car.... *sigh*
That sounds like a flattish battery. Easily caused by playing with an OBD tool unless you use a battery maintainer (a charger, basically) or keep the engine running.
Old Jun 11, 2013 | 07:36 AM
  #344
prolepsis's Avatar
Default Which version of IDS SDD to acquire?
aa
Old Jun 11, 2013 | 05:18 PM
  #345
plums's Avatar
If you are using anything other than the version supplied by Jaguar, then you are entering into the area of bootleg software unless you happen to be a tech who had access to a copy originally obtained from Jaguar directly. Therefore, all the usual cautions apply including caveat emptor. The key to ebay is to review the negative buyer feedback *and* look for a long history. In this particular niche, it seems that the ebay vendors are far removed from the factory. Use the usual web vendors instead.
Various posters have cited the specific software versions they have used including the sub version in this thread. So, you will want to go back and find those.
Be aware that if you are buying a non-genuine device, the vendor will normally ship a DVD anyways.
Old Aug 7, 2013 | 04:25 AM
  #346
Mike V's Avatar
Default Radio
Has anyone had any luck using the Mongoose JLR to change the entertainment radio module?
For example, 2 things I would like to do is add the AUX option to the radio to get the Audio Connectivity Module I installed to work.
and second, since I'm currently in Europe I'd like to change my radio frequencies to pick up .even numbers as well (US radio settings only have .odd frequencies).
I have a 2008 XKR (X150, US spec).
Old Aug 8, 2013 | 11:30 AM
  #347
Jagboi64's Avatar
I have a 2007 X Type and changed to the navigation system from standard. I bought a radio from Ebay UK ( I'm in Canada) and it had the European frequencies. I was able to change it to the North American frequencies with the Mongoose tool and SDD V131, but it wasn't easy to do. There isn't a radio setup option or anything, you have to go through the symptoms. Eventually I was able to find it under the "extras" tab I believe. However, I did have to go through the diagnostics first to get the extra tab to appear. I think what brought it up was clicking that the radio didn't work.
Experiment and be patient and you'll get there in the end.
Old Aug 12, 2013 | 05:43 AM
  #348
meirion1's Avatar
Finally got my mongoose to work properly after months of on and off effort.
I have read the training manual on this forum but I can't see where all the detailed
information about the car is.OK I have no warning light up and did not expect to see
any codes but it did not even say-No codes found!
I am beginning to think it is as clunky as the sat nav!
maybe I need a dtc first.
Old Aug 30, 2013 | 06:21 AM
  #349
Mike V's Avatar
Default Training Manual
Originally Posted by meirion1
I have read the training manual on this forum .
Could someone please provide a link to the training manual? Please, tried a search and couldn't find it.
Old Aug 30, 2013 | 06:34 AM
  #350
plums's Avatar
They are all linked in this thread itself.
Old Sep 10, 2013 | 05:17 PM
  #351
XJRTrooper's Avatar
Wow! I was interested in buying a programmer, but am now scared to death to undertake such a venture!
Old Sep 10, 2013 | 05:57 PM
  #352
plums's Avatar
You could consider that the vendors would have to sell at least into the hundreds of units to make the venture worthwhile.
Do you see hundreds of failures?
It would be safe to presume that the usual case of the dissatisfied customer complaining the more often than a satisfied customer praising a product to hold true for this product just like any other product.
Of course, it is always open to a user to buy any one of the J2534 products listed by Jaguar as being on the approved list. The two Drew Technologies products range in price between $500 and $1800.
Even with those products, there is the question of user error and judgement.
Give a guy a zip gun or a glock ... he can still manage to blow off his foot with either one although the glock is probably safer to carry and has a safety.
Old Sep 14, 2013 | 08:56 AM
  #353
Mike V's Avatar
Default Acm
Ok, I've installed the Jaguar Audio Connectivity Module on my 2008 XKR The last step is to activate the auxiliary option on the audio menu using SDD.
I have v134 with a Mongoose. Right when I start to execute adding the AUX option the SDD session gives me a time stamp then the message:
"It is essential that the software status is updated to the latest version prior to performing a vehicle module software download"
Then tick to continue and no AUX option.
Can anyone tell me what this message means?
Thank you
Old Sep 21, 2013 | 05:56 PM
  #354
meirion1's Avatar
I think you need to go back to v131 or earlier.After v131 you need a Topix subscription.
Buy the genuine Jaguar/land rover software from ebay, about $30.
Your Mongoose should work with that but you need the interface driver as well.
It is available on this forum.
Old Sep 26, 2013 | 11:55 AM
  #355
capt's Avatar
Default JLR Mongoose install problem.
New install using version 128 on XP Pro, sp2, IE6, early Mongoose driver etc. I get to the SDD Tools page and see (the vcm is disconnected). When I connect the Mongoose cable it recognises it and says it's the wrong device. It will not let me continue to the next page. I see no way to enter any system setings to change the device to mongoose? Do I need to remove the vcm drivers that may have been installed automatically? HELP!
Old Sep 26, 2013 | 12:15 PM
  #356
ledstyle's Avatar
Hi all, New in here....
I have trouble, I need software that can program (not just code reader) etc. my 1999 S-type.
I already have Autocom but it doesn't cover this year, only 2001 -->
So I was looking IDS or Mongoose (Clone is fine as the price is lower) But I'm little confused when i look details of these deals... Other says 1998 upward and other that only from 2005 upward...
HELP.
Mongoose says that only x202...is it true?
Old Sep 27, 2013 | 12:43 PM
  #357
capt's Avatar
"Update" I found that by connecting the Mongoose to the computer first and letting it load drivers, then opening ISD it now communicates as it should. This may not be the correct solution but seems to work for now.
Old Sep 30, 2013 | 02:22 AM
  #358
tonicar's Avatar
Default i need IDS software for AVDI PASSTHRU
Hi, i have a avdi scanner but i need the ids softwarwe to run it on avdi so if can anyone send me the link or the software .thank you very much.
Old Oct 2, 2013 | 03:37 AM
  #359
Krasi's Avatar
In the past few days I've read quite a bit about JLR, J2534, this thread, etc., and have a rather lame question:
As plums has stated earlier, "The Mongoose is a protocol converter, nothing else." On one side it has J2534-1/2 standard, and on the other a number of industry standards (CAN, J1850, ISO9141, etc.).
As far as I can tell, there are other such "standard" protocol converters (see attachment). Is there something really special about Mongoose design/operation that other converters don't have? Do they really utilize one, or more, of the "Manufacturer discretion" lines from the OBDII J1962 connector to do full diagnostics?
I mean, what do you think will happen if you run JLR through a non-Mongoose converter? Or IDS on a Ford vehicle? Get "generic" OBDII diagnostics only? As this is the original idea behind the J2534 and "pass thru" concept, right?
Just thinking out loud here, which maybe is total rubbish....
Old Oct 2, 2013 | 03:55 AM
  #360
plums's Avatar
You would need to verify capabilities with the particular vendor.
There are only three devices on the "approved" list from Jaguar.
In the case of the Mongoose, it has to be the Jaguar specific version. That is because there is one particular signal used by Jaguar and implemented in that version that is not implemented in the other versions.
