Ford/Jaguar WDS Genrad GDS3500
  #101
Old 03-16-2017, 06:48 PM
BoostedFord's Avatar
You would think so but my unit came from a ford dealership and it doesnt even have all the software....
That would be great if you could upload the .iso of the cds then i can just burn them onto a disc.
I'll try and send you a pm bob not sure if i can yet
  #102
Old 03-16-2017, 08:38 PM
motorcarman's Avatar
Received 7,896 Likes on 4,770 Posts
Got the PM and I started an upload of B45. I need to convert some Ford stuff to .iso
I never use the Ford software but I keep it because the WDS units I have are all Ford and came with software.
I also have install instructions for B45.
bob
File Type: pdf
BoostedFord (03-17-2017)
  #103
Old 03-21-2017, 10:27 AM
Vee's Avatar
Vee
Vee is offline
Received 1,512 Likes on 1,177 Posts
I think I'm going to join this club. I believe I have located a WDS machine, with the dock.
It apparently works, but comes with no accessory cables. What cable would I need to connect it to my 1996 Jaguar XJS. I'm assuming there's a 20 pin cable with an OBD2 end?
  #104
Old 03-21-2017, 02:15 PM
You should have a B203 and A204.
The B203 is an absolute must. The A204 will be needed if the PTU software requests it.
bob
  #105
Old 03-21-2017, 04:41 PM
Vee's Avatar
Vee
Vee is offline
I don't suppose anyone has a copy of IDSv130 lying around... I can't seem to get my cloned mongoose to communicate with the XJS with anything newer
  #106
Old 03-21-2017, 05:06 PM
IDS stopped at 118.5 SDD then continued onward. I have SDD 121,125,126,127,128,129,130,131.
When I had a Mongoose Pro I never tried to use it on XJS or 1995> XJ6.
I bought a VCM and sold the Mongoose.
I have WDS so that is what I use on the old cars.
bob
  #107
Old 04-02-2017, 11:08 PM
davideliarosenbloom's Avatar
Default to motorcarman
Dear Bob:
I recently had a 0753 and 0748 fault after a 1647 which cleared. However faults returned and stayed in gear box fault mode.
I replaced all the solenoids as I thought at 135k the indication solenoid A was one that historically on the web looked good. Started up and cleared codes and then immediately on the 2-3 shift (could have been 1-2 shift). DIfference now is that when I stop and turn the car off the codes clear themselves so to speak, and I can run the car with no fault light (unlike before) until the first 2-3 shift whereupon it goes into fault mode and sets a 0753 ONLY code
I think I installed everything correctly although on the top third solenoid over from battery there was this metal solid "V" shaped "stabilizer(??) about 3/8" x 1" that did soemthing I dont know what and I didnt get that into the correct position. Any thoughts? Could something be stuck inside the valve body? It first occurred while cold.
Thank you do much! WOuld you mind contacting me off list?
Dave david@duiutah.com
  #108
Old 04-03-2017, 12:51 AM
JagV8's Avatar
Received 4,488 Likes on 3,905 Posts
All codes start with a letter... And you look to be in the wrong forum. Worse, this is the wrong thread too.
  #109
Old 04-03-2017, 03:39 AM
Just a update.
With many thanks to Bob for uploading the .iso files im now running software version B45.4 P1 and the unit is working as it should with the module programming working.
WDS newbie (07-11-2021)
  #110
Old 04-03-2017, 02:15 PM
Does the B45 work on all the Fords? I have B43 but I usually let other people use it to work on their Fords.
bob
  #111
Old 04-07-2017, 04:08 AM
bob
I have no idea all i know is that it works on all aussie built ford's up to September 2006
  #112
Old 04-18-2021, 11:02 PM
WDS newbie's Avatar
I have a list of the WDS software CDs I have!!!
Ford
A5
A6
B37
B40
B41
B42
B43
C4 discs 1 & 2
C5 discs 1 & 2
I also have B44 and B45 that a European member sent to me but I don't know anything about them. I don't know if they are for European models or some sort of 'patch' before the IDS introduction????
Jaguar
CD-2 (latest 'ghost disc')
JTP 759 Disc Issue 23
JTP 759 Disc Issue 24B
JTP 759 Disc Issue 28
JTP 759 Disc Issue 29
JTP 759 Disc Issue 35
JTP 759 Disc Issue 38
JTP 759 Disc Issue 41
JTP 759 Disc Issue 42A
JTP 759 Disc Issue 42B
JTP 759 Disc Issue 43
Anyone wanting to trade or obtain any of these disc, let me know.
bob gauff
Hello motorcarman
I am working on a project which I hope will eventually land me a Range Rover P38 running with an AJ133 V8 engine.
I currently own a WDS unit with Ford software, and I would like to purchase some software from you.
I'm interested in a copy of CD-2 (latest 'ghost disc'), JTP 759 Disc Issue 43.
Is the software JLR or only Jaguar?
Would I need to install all previous versions of software before I can install 43?
Regards
Rob
  #113
Old 04-19-2021, 07:24 AM
Received 1,420 Likes on 1,063 Posts
If anyone is interested I have a working WDS for Jaguar with V43 installed. OBD cable and elusive battery cable. I have access to the docking station as well.
This was mine previously and I reacquired it.
I rebuilt the battery pack back in the day.
I do not need this as I have a VCM and IDS.
If interested send me a PM.
WDS newbie (04-19-2021)
  #114
Old 04-19-2021, 09:32 AM
Originally Posted by WDS newbie
Hello motorcarman
Regards
Rob
The WDS was never used by Land Rover as far as I remember but they did used the IDS Rotunda VCM because we (Jaguar shop) borrowed it from Rover (across the street) when our VCM failed. Jaguar Tech Hotline told us to borrow the Rover unit to finish what we were doing and they sent a replacement VCM overnite.
The IDS software does have Jaguar and LR choice on the Splash Page to enter the VIN. I never chose LR cause I don't work on them.
I have JWDS_ENG_4 (CD2 Ghost) WDS 43 (CD42a and 43) on a MY DRIVE site.
Send me a PM and I will get you an INVITE to download the software.
bob
  #115
Old 04-19-2021, 04:25 PM
WDS newbie's Avatar
bob
Oh ok.
I have a Rotunda VCM however I think it may be faulty as it goes through its power up cycle but it doesn't communicate with my pc.
That could also be my pc playing up.
Rob
  #116
Old 06-24-2021, 10:13 AM
clubairth1's Avatar
Received 2,251 Likes on 1,775 Posts
Thanks for the work but it requires a sign up or account of some kind?
Anyway you can remove those requirements? I have used dropbox before and it just let me download the documents with no other requirements.
  #117
Old 07-09-2021, 04:18 PM
astondoc's Avatar
Hi Bob, I have all the Aston Martin Discs, Even a PDU disc for any one that might have an old PDU laying around.....I need Jag discs and willing to trade or buy....Hopefully it will cover my 04 XJR....
Ken
wren
General Tech Help
47
08-16-2023 09:27 AM
Cottonwood
05-06-2017 08:13 PM
10 XF Premium
04-15-2015 07:44 PM
mjlaris
11-03-2012 12:37 PM
bojangles
05-03-2009 05:11 PM
Quick Reply: Ford/Jaguar WDS Genrad GDS3500
