KNOCKING NOISE at front suspension
Old May 20, 2017 | 04:20 AM
flatestcat's Avatar
Default KNOCKING NOISE at front suspension
Hi, Through a process of elimination, we are trying to locate a knocking noise in the front of my 2002 S type 4 litre Jaguar. The ball joints have been checked ( tick) steering rack is good.checked 4 bolts on the lower control arm that you adjust when giving a wheel alignment - all good. Every nut has had a spanner on it to check for being tight - all good. running out of options. Could it be engine mounts? could it be the struts ? Could it be the top bearing strut mounts. The noise is on both sides. Knock knock knock going over pot hole and even knocks while slowly driving over a speed hump in carparks.I am at a loss .I don't want to throw money on a part unless it's the answer to the problem. I'd like to get noise / mike sensors wifi to a laptop while driving to locate the noise. I need help with this please.. glennrboyd@gmail.com Australia
Old May 20, 2017 | 04:34 AM
ronstrutt's Avatar
Default knocking noise
My problem was, Swaybar links. And Grummet under air box, and inner plastic wind/dirt guard on the other side all loose.
Old May 20, 2017 | 05:58 AM
Both mine needed swaybar "D" rubbers to shut them up.
Nothing else.
Well documented "knock" in the S Types, especially the X200 series.
Left Hand is simple, Right Hand is PITA, as heater tap needs removing for access.
Forgot, I do that.
Welcome to the Forum.
When time permits, please do an Intro in the New Members Area, and any vehicle related issues are best in the S Type, X200 section, where many more members will see your ask.
Old May 20, 2017 | 07:37 AM
JagV8's Avatar
In case of more troubles please post in the right forum.
Here https://www.jaguarforums.com/forum/s...ed-v8-x200-15/
Old May 20, 2017 | 07:06 PM
motorcarman's Avatar
I will post it again for the new guy!!!!!!!
bob
-Greg-
Apr 7, 2017 04:08 PM
withstu
Mar 25, 2017 04:37 PM
gkubrak
Mar 12, 2017 04:34 PM
allan320
Mar 6, 2017 11:14 PM
vdpnyc
Feb 22, 2017 11:34 PM
