SDD said it couldnt clear all codes
Old Dec 8, 2019 | 09:05 AM
Aarcuda's Avatar
Default SDD said it couldnt clear all codes
200) STR. SDD 131.03 v 116. I get this message when messing with modukes.
Old Dec 8, 2019 | 01:47 PM
JagV8's Avatar
And when you did what it says, what DTC(s)?
Old Dec 9, 2019 | 10:10 AM
Aarcuda's Avatar
It shows no codes.as far as I can tell but it get this message every time I try
Old Dec 9, 2019 | 10:30 AM
jackra_1's Avatar
I had something similar using the same version of jlr sdd with my transmission. I only had the one code which I think it stated it was a "hard code" or fault.
It was a P0730 code which is a "permanent" DTC
Which is why, along with a seal leak, I am going to rebuild my transmission.
Old Dec 9, 2019 | 09:34 PM
hafren's Avatar
IIRC 0x9676 is dtc code B1676 so can you lookup that code in the workshop manual to see if that explains it.
Old Dec 10, 2019 | 07:38 AM
jackra_1's Avatar
http://www.jaguarforums.com/forum/xk...t-range-67816/
Look at the above thread.
Old Mar 19, 2020 | 04:42 PM
Aarcuda's Avatar
Originally Posted by jackra_1
So it doesnt appear that the issue in the link post is my problem.
I wonder if maybe my battery charger is too high causing the fault. I know its not low because SDD shows the battery indicator as Green in the upper right of the SDD screen.
Any other ideas?
I do have a problem with my front park sensors. SDD shows they should be working but theres no sound.
Old Mar 19, 2020 | 06:19 PM
JagV8's Avatar
Unless it's destroyed the battery it's rather unlikely to be too high.
It could have other problems (e.g. too much ripple), but being too high - well, you'd know if it destroyed the battery I reckon.
You can check "too high" fairly easily e.g. is it over 15V when connected? Disconnect it if it is!
Old Aug 5, 2020 | 11:47 PM
Aarcuda's Avatar
well an interesting week for sure. I picked up an Iota DLS-55 battery charger that is very similar to the Midtronics. It puts out a solid and stable13.4v with 55amps. And using that instead of my old fashioned unregulated battery charger I was able to reconfigure the pcm and tcm which I could never fo before. The SDD module configuration routine would fail every time
and guess what? It actually cleared all the codes for the first time ever! So im gonna say the battery voltage is critical here.
altijag
Jun 13, 2025 12:53 PM
texevora
Nov 6, 2023 05:20 AM
DevonDavid
Dec 21, 2016 11:08 AM
Bladevane
Feb 11, 2014 02:23 PM
ejjbee
General Tech Help
Jan 30, 2013 11:34 AM
