Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
How to tell the AJ26 engine from AJ27
Old Jan 23, 2015 | 01:55 PM
brantman's Avatar
Question How to tell the AJ26 engine from AJ27
I noted a post where a member bought gaskets and tensioners for an AJ27 engine only to discover his was an AJ26. Just how can you tell if you have the newer AJ27 or the earlier AJ26? To most of us they look just alike. I have searched for "images" of each only to get the same exact photo displayed for both! I'm about to launch into the timing chain preventive replacement ordeal and need to know. Also, I note that Lincoln LS 3.9 engine pieces are half the price of JAG, so if you are on a limited budget why not use them?
Old Jan 23, 2015 | 06:18 PM
Cambo's Avatar
From what I understand there are a few indications;
1. The VIN of your vehicle will state if it's AJ26 or AJ27 from 2000MY onwards
XK8/R, 11th digit in your VIN; C=AJ26, E=AJ26S, N=AJ27, P=AJ27S
XJ8/R, 11th digit in your VIN; A/B=AJ26, D=AJ26S, K/L=AJ27, M=AJ27S
2. The throttle body of an AJ26 has a large vacuum canister for the cruise control, the AJ27 does not
3. The coils on the AJ26 are 2-wire, the AJ27 has 4-wire coils.
BUT
The supercharged cars had a grey zone where the electronics were AJ27S but the engine itself was AJ26S...but since you have an XK8, that shouldn't affect you.
Old Jan 23, 2015 | 06:28 PM
brantman's Avatar
Default AJ26 vs AJ27.
My VIN is "A06528" so it must be an AJ26...but it has no canister that I can see. In photos I can see a canister that is about tomato can size and has what appears to be a vacuum hose coming out of the top. Mine does not have that. I just put the coil covers back on an hour ago, but did not count the wires. No big deal to pull off again. If it has 4 then I'll assume it is an AJ26 & 1/2.
Old Jan 23, 2015 | 06:44 PM
Cambo's Avatar
The 11th digit of your VIN is the one before the "A"
Old Jan 23, 2015 | 07:14 PM
brantman's Avatar
Default AJ 26 vs AJ 27
I went back out and pulled the coil cover off once more....and they have
4 wires.
I then went back out and checked the VIN again...NA06528.
This car was traded back to Hennessy in Atlanta with less than 9,000 miles on it, so I was beginning to think they had replaced the engine. Maybe not.
So, am I safe with regards to the tensioners, or should I pull the valve covers off and take a peek? Whatja think?
Old Jan 23, 2015 | 07:46 PM
Cambo's Avatar
Definately an AJ27 then...
Unless you have documentation proving that the tensioners have been replaced to the 4.2L version (p/n: C2A1511 + C2A1512) then I would change them out, even if the engine only has 9000mi on it.
Old Jan 24, 2015 | 11:55 AM
brantman's Avatar
Thanks, CAMBO. That information is exactly what I needed to hear. I will pull one side of the engine covers off and see just what is in there. If it is plastic, I'll have the entire timing chain system redone, 1st and 2nd, chains, guides and water pump. I understand that some 2000 models have steel tensioners, but I think mine is fairly early in the production year and, at best, has the 2nd gen plastic installed. 49,000 just rolled over.
Old Nov 16, 2020 | 02:52 PM
Jasonh97's Avatar
BUT
My 11th character is K but the coils only have 2 pins, do you know where the engine stamping is. Also whilst I'm talking about contradictions its a year 2000 and the identification plate states it an x300 but I would of thought it should state x308 shouldn't it?
Old Oct 23, 2022 | 05:25 PM
keirconway's Avatar
To confuse matters even more i have an aj27 with the 11th digit being H 😂 and 4 wire coil packs. Built in 04 1999🤷
Old Oct 8, 2024 | 04:21 PM
Cyrilmoto's Avatar
Default 1999 XK8 with 2003 engine block. AJ26 or AJ27?
Hi...
I also have adventurous days..
I wanted to order a set of valve cover gaskets, both secondary tensioners, the thermostat tower and other little things before starting work on the car. But the seller requests information about the type of engine. And so I got stuck and traveled here in search of an answer to this question. The car was built in February 1999. I found the engine number with the help of local experienced members! (Thank you very much gentlemen!)
The engine has a build date of 2003 04 09. So is it the whole engine or just the block (?). In the form of the registration office it is stated - engine 3AJD M 8626, engine change on September 18. 2003.
Okay. Is it AJ26 or AJ27? In the US VIN, it is in position 11. C - that is, AJ26. And could such an engine be installed in a block from 2003? I really don't understand this!
To find out for sure and order the correct parts, I'll have to open up the engine and see what the puzzle is.
I am not happy about this scenario at all!
Thanks...Cyril
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
