1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap
Old Jul 8, 2018 | 01:47 PM
  #221
lickahotskillet's Avatar
Default putting words together
Jon,
I have to be careful when using Doug's description and yours together in the same sentence - "Certifiable lunacy".
On my "77 XJ12L with the BBC, I use the line loc to warm the tires. If you don't set it hard enough and apply the power gradually, the rear lights up, and pushes the car left and sideways down the road. So this is risky at the track, because you can push yourself into a "red light".
So to answer your question, yes for burn outs, or to warm the tires prior to launch at the drags. Since both are mostly street cars or a to be a street car., I use the line loc to fill the neighborhood with tire smoke. Kids (young folks) across the street drive "coffee grinders" (four cylinders) with fart can mufflers. So the '77 burnouts help them understand the meaning of "Wow, I could have had a V8!"
Old Jul 8, 2018 | 01:51 PM
  #222
Default Sliding door with stepper motor
Jon,
you have to careful with the "sliding door controlled by a stepper motor" over engineered idea. Primaz will try to incorporate it before I or you get the chance.
Old Jul 9, 2018 | 01:31 AM
  #223
TilleyJon's Avatar
Have to say that would be pretty cool on the street, the neighbors must love you !! Hilarious.
I bet Primaz is already ten steps ahead of me .
Old Aug 23, 2018 | 09:07 PM
  #224
Default A line a day
First - Doug - thanks for the tip on the line straightener!
Slow and methodical was the procedure, right and tight was the by word. It was sit and stare, asking myself "where does this line belong, is it interfering with anything, is it away from heat, etc.
A youtube video lead me to use the braided stainless at the master and the line lock.
Front to rear had to be three piece. Line on the floor and bench is RF. If you want it back out in one piece - pull the engine and tranny.
Thanks for looking!
Old Aug 25, 2018 | 12:44 AM
  #225
TilleyJon's Avatar
More nice work Clyde, now I realise it's your assistant that does all the graft and not you, the first pic gave that away !!
Old Aug 25, 2018 | 09:58 AM
  #226
Jon,
Bandit is just a stuffed prop.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo425.jpg
Old Aug 25, 2018 | 11:28 AM
  #227
TilleyJon's Avatar
Pop him in the post I'll put him with the others they can all not watch.
I like Bandit, he's great, what a chilled dude.
Old Aug 25, 2018 | 12:39 PM
  #228
Jon,
Bandit also likes creeper rides around the shop.
Cheers.
Old Aug 27, 2018 | 03:37 PM
  #229
TilleyJon's Avatar
I bet you have a V8 on the creeper too !!
Old Sep 16, 2018 | 08:17 AM
  #230
Jon,
No V8. Just tried used XJ12L leather on my creeper seat, too slippery.
Moving along - front suspension & steering in. Column overhauled with both felt (cut to size) and the rubber bushings. Graphite moly grease on the felt and dielectric grease on the rubber.
Minor screw up on the lower rear shock mounts - Mis-read & over torqued. New bolts on Monday. Tank in for line line installation boot to engine compartment.
Old Sep 16, 2018 | 08:19 AM
  #231
Pictures did no go with last, let's try again.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo633.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo427.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo307.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo741.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo474.jpg
Old Sep 16, 2018 | 12:46 PM
  #232
csbush's Avatar
Very nice! It looks like it is really coming together
Old Sep 16, 2018 | 01:23 PM
  #233
Thanks chuck. A couple of trips will get in the way shortly. Then it will fuel routing, then the biggie - WIRING. Then on the ground for engine, trans, drive shaft (needs measures & ordered). Radiator install and all the engine plumbing and wiring.
YIKES!
Cheers,
Old Sep 17, 2018 | 04:08 PM
  #234
Jamming to Dave Hole radio on pdora, tightening jam nuts.
Rear coil overs in, and rear suspension torqued to spec.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo444.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo6.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo656.jpg
Old Sep 17, 2018 | 04:15 PM
  #235
Additional info: petrol tank is 22 US gallons. No golf clubs, or roll out printer, fax, copier, and portable bar.
Old Sep 17, 2018 | 06:52 PM
  #236
MK2's Avatar
MK2
Art work, Clyde. Just beautiful!
Lin
Old Jan 11, 2019 | 07:17 PM
  #237
Cheers everyone, and Happy New Year.
Fuel lines are in from the pressure regulator in the firewall to the tank in the boot/trunk.
100 micron pre filter, 440 gallon per hour pump, 10 micron post pump filter. -10 AN Out of the tank, -8 AN out of the pump to the regulator, and -6 AN return.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo636.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo234.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo915.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo360.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo411.jpg
1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo965.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo290.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo166.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo568.jpg
Old Jan 11, 2019 | 07:20 PM
  #238
Onward. Electrical next. Filled the table with some of what's next.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo842.jpg
Old Jan 12, 2019 | 12:46 AM
  #239
TilleyJon's Avatar
Nice Clyde, very nice. Which MSD controller are you going with as a matter of interest ?
Wiring ah what fun !
Old Jan 12, 2019 | 08:28 PM
  #240
Jon,
The coil and box are suppose to be good for long hours of operation.
Attached Thumbnails 1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo361.jpg   1960 MK2 not a restoration, not a rusto rod, just a Bonus Trap-photo125.jpg
