Battery bracket rubber
Old Jul 28, 2024 | 07:47 PM
cdg66mk2's Avatar
Default Battery bracket rubber
A simple question, I think. There is a rubber strip that attaches to the bracket that holds the battery in place. I assume that is just glued to the metal bracket? If glued, is it cut in the corners or just pushed into the bracket corner as far as it will go?
For some reason, I have two rubber strips. One is older and seems to fit on the bracket very nicely. The newer rubber seems to be too narrow. It's as if they found an extruded rubber material that was "close enough" and sold that as the bracket rubber. The bracket is after market, too, so maybe that is the issue.
Thanks in advance
Craig
Old Jul 29, 2024 | 04:42 AM
Glyn M Ruck's Avatar
Not glued. Held by profile & Thackeray washers on brass holding bolts on the metal strap. You can glue if you wish.
Thackeray washer
Old Jul 29, 2024 | 05:02 AM
Refresh Page for addition.
Old Jul 29, 2024 | 09:37 AM
Jose's Avatar
or use door edging trim which stays in place with its own adhesive but it is removable.
also it is thicker and keeps the metal bracket away from battery acid.
not original but does the job.
Old Jul 29, 2024 | 11:05 AM
Battery acid has no effect whatsoever on the "rubber"
Old Jul 29, 2024 | 04:12 PM
cdg66mk2's Avatar
Thank you for the input, gentlemen!
I have had the Thackeray washers on my buy list for some time and no one seems to have them. Probably time to look again. I may have to get creative until I can find them.
Old Jul 29, 2024 | 04:55 PM
Jose's Avatar
all Jaguars must have used those spring washers in one place or another.
In the XJ-6 Series 3 (1980-1987), they are used in the pull handle to open the bonnet, so a salvage yard will have them.
Old Jul 29, 2024 | 05:10 PM
Argh! They only have 1 in stock
https://mossmotors.com/catalogsearch...keray%20washer
David Manners found mine.
https://www.abingdonmgparts.co.uk/pr...A--mgb/ajd7731
Old Jul 29, 2024 | 05:12 PM
The MG shops use many different sizes of Thackeray washer.
Old Jul 29, 2024 | 05:31 PM
Part Number FG.204/X
Jeffkrell
Feb 15, 2024 05:40 AM
BenKenobi
Jul 15, 2022 02:05 PM
BenKenobi
Jun 22, 2022 10:50 AM
adenshillito
Jul 13, 2021 06:40 PM
Doug
Jun 15, 2018 01:05 PM
