1st '04 Jag XType 3.0 AWD
Old Feb 24, 2014 | 07:20 PM
slyjag04's Avatar
Question 1st '04 Jag XType 3.0 AWD
Hi Everyone,
Just bought a 04 Jag XType 3.0 AWD (black/black). It's not running and got 2 diagnostics from a local mechanic and a Jag dealer. Both said faulty fuel pump is the cause. I have been researching on how to change the pump prior the purchase. Just wanted to say hi and looking forward to get on this project when the weather gets warmer and the snow will stop here in Pennsylvania. I will try to document the project as much as I can for everyone.
Here it is:
1. 02/23/2014 - changed the fuel filter ($10); still didn't start. Old fuel filter was installed with the arrow point back to gas tank? The tip was bended also.
Wish me luck!
slyjag04
Old Feb 24, 2014 | 07:49 PM
Bad Cattitude's Avatar
Welcome!
Old Feb 24, 2014 | 08:36 PM
Welcome to Jaguar Forums slyjag04,
If you need any kind of tech help with the repairs head this way X-Type - Jaguar Forums - Jaguar Enthusiasts Forum and you will find others from your area and news of events etc in the regional section North East US - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
Old Feb 24, 2014 | 11:06 PM
Welcome to the forum slyjag04,
Follow Norri's link to the X-Type forum for help, advice and information.
Good luck and enjoy the forums.
Old Feb 25, 2014 | 05:40 AM
welcome to the forum - you'll find plenty of info and support here simply follow the links Norri has provided - enjoy
Old Feb 25, 2014 | 05:53 AM
Five Speed's Avatar
Hello & welcome , great to see you here ... I did NYC & some PA in 1994 in a 94 Chrysler Imperial . stopped around the Bushkill , Poconos, Marshalls creek , Jim Thorpe area .....Nice state ( but didnt see it all )
Old Feb 25, 2014 | 07:14 AM
Schwabe's Avatar
welcome and enjoy the board
Old Feb 25, 2014 | 07:49 AM
SNG Barratt USA's Avatar
Former Sponsor
Welcome to the forums!
Old Feb 27, 2014 | 01:32 PM
search facility etc, can be found here within the following link Helpful_information
__________________
Old Mar 5, 2014 | 07:46 AM
slyjag04's Avatar
Thank you...
2. 3/2/2014 - Tried to siphen to the gas by using a 1/2" & 1/4" tubes but couldn't reach the gas tank...another obstacle! I was able to back the car up a set of rams w/ the help of neighbors. Also, found a pump from a junk yard for cheap (will pick it up this Sat).
Old Mar 5, 2014 | 07:56 AM
I recall one member reporting an issue with the anti-siphon device in the fuel filler pipe becoming dislodged and making subsequent fill ups a slow nightmare so be careful.
Jaguar don't make it easy!
Old Mar 10, 2014 | 10:56 AM
slyjag04's Avatar
3. 3/8/14 - 3/9/14
*** Got a gas tank ('07 Jag) w/ everything w/ it from a junk yard (waited 3 hrs for it!)
*** Got the drive shaft & muffler to drop (lots of WD40/Blaster & elbow grease); cutted off the bracket holding the muff b/c I could not get the nut to turn (even tried the torch).
*** Dropped the gas tank w/ about 11 gallons of gas still in it (w/ the help of a few jackstands) - had to cut the "fuel filler neck hose" b/c the clamps on it totally rusted out.
*** Ordered the "fuel filler hose"; will try to put everything back next week!
I want to say thanks again (got a few tricks & tips from this forum).
Attached Thumbnails 1st '04 Jag XType 3.0 AWD-img_1047%5B1%5D.jpg   1st '04 Jag XType 3.0 AWD-img_1054%5B1%5D.jpg
Old Mar 10, 2014 | 12:08 PM
I'll not be picking any fights with anyone who you can handle a tank with 11 gallons in it!
Sounds like you've got everything together now. Good luck with the rebuild.
Old Mar 18, 2014 | 09:53 AM
slyjag04's Avatar
4. 3/15 & 3/16 - managed to put everything back as is but still no power to gas pump. Ordered a fuel pump module to swap out just in case.
***Notice someone (mechanics) has messing around w/ the module and didn't bolt it back in. Can't wait until the module arrive. I think this is problem!
Shawn Svacha
Nov 4, 2019 02:47 PM
Jjscruggs1
Aug 2, 2017 04:40 PM
cissdm
May 3, 2016 06:02 AM
nd143
Sep 3, 2015 04:42 PM
King Charles
Sep 3, 2015 12:40 AM
