2000 S Type stumbling Issue at 45 mph
Old Mar 1, 2016 | 02:58 PM
Tmjag2000's Avatar
Default 2000 S Type stumbling Issue at 45 mph
Hi all, I purchased a 2000 S Type 4.0 , check engine light was on so I cleaned the intake plumbing and cleaned the Throttle body without removing it , I also cleaned the Air Assist Control Valve , I drove the car around for about 20 miles then punched the gas and the check engine light turned off. Now the car has a Stumbling idle after the engine has reached normal temperature , I notice this at a stop light . The car accelerates with no problem but when I reach 45 mph the engine stumbles /stutters , I give it more gas and the problem stops and runs great...
Has anyone had this issue or can someone guide me in the right direction to fix this problem..?
Old Mar 1, 2016 | 03:02 PM
Tmjag2000's Avatar
Default 2000 S Type stumbling Issue at Idle & At 45 mph.
Old Mar 1, 2016 | 06:44 PM
Hello,
Someone will be here shortly to direct you to our S-type section where you can get help with that.
Old Mar 1, 2016 | 06:51 PM
Welcome.
A quickie repost in the S Type section should have answers, but a code read would be my first best guess, then specifics can be sorted.
Also mention the kms/miles travelled, age of coils/plugs/O2 sensors/etc.
Might also help to know where you are, as some markets have stuff that other markets do not.
Old Mar 1, 2016 | 06:54 PM
Tmjag2000's Avatar
I'm in Southern California. No codes are showing up. Spark plugs are good and correct coils are also clean..
Old Mar 1, 2016 | 06:55 PM
Tmjag2000's Avatar
My Jaghas 122,000 miles.
Old Mar 1, 2016 | 07:07 PM
Welcome.
A quickie repost in the S Type area should get some answers.
I would slos add:
Your location, different markets, different stuff.
Kms/miles travelled.
Any codes stored.
Service schedule regarding plugs/coils/O2 sensors/etc.
Battery age, Not funny, many STRANGE issues have been traced to a dying battery.
Old Mar 1, 2016 | 07:11 PM
Tmjag2000's Avatar
There was a p0065 code , cleaned MAF , throttle body, air assist valve.. I drove it 20 miles then gassed it on the freeway and check engine light turned off...
Old Mar 1, 2016 | 07:12 PM
Tmjag2000's Avatar
New battery. About a year old..
Old Mar 1, 2016 | 09:33 PM
Daf11e's Avatar
Welcome aboard.
Old Mar 1, 2016 | 10:29 PM
skipro152's Avatar
Welcome to the forum. Post your question in the S Type Section of the forum and I'm sure you will receive some advice. Good luck with your new Jag!
Ed
Old Mar 2, 2016 | 04:26 AM
Welcome to the forum Tmjag2000,
(I've merged your two identical Intro threads - please do NOT multiple post)
I can see you've already found your way to the S-Type forum so there's no need for a link to it from me.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Western Region forum by following this link https://www.jaguarforums.com/forum/western-us-ak-ca-nv-ut-hi-wa-id-38/
Enjoy the forums.
Old Mar 2, 2016 | 04:45 AM
o1xjr's Avatar
Old Mar 2, 2016 | 05:42 AM
Welcome to Jaguar Forums Tmjag2000,
Old Mar 2, 2016 | 06:31 AM
Old Mar 2, 2016 | 07:00 PM
NBCat's Avatar
Most likely coil pack(s), which may or may not set a DTC and turn on the MIL. Do you know if the spark plugs have been replaced?
If you encounter a situation when the MIL begins flashing, continuing to drive under those conditions causes permanent damage to the catalytic converters.
Old Mar 5, 2016 | 03:00 PM
Using JF "How To"
Nookpad
Mar 1, 2016 09:28 PM
EE/ME
Feb 2, 2016 11:59 PM
user 652867429824
Feb 2, 2016 11:12 PM
Daniel Thomas Eakin
Feb 2, 2016 02:31 PM
philwarner
Feb 2, 2016 10:54 AM
