ac compressor removal instructions 1988 sjcs
Old Jun 9, 2011 | 01:18 PM
jjborst1's Avatar
Default ac compressor removal instructions 1988 sjcs
I was wondering if anyone can tell me the steps for removing a ac compressor I am not a mechanic but will not pay the price they want .If not any good manual out there for this task.
Old Jun 9, 2011 | 04:44 PM
Fraser Mitchell's Avatar
First thing to do is not to attempt removal without extracting the refrigerant gas into a closed tank, i.e. do not vent it to atmosphere, it is illegal and dangerous. Air con specialists are the ones who have the kit to do this, and I am not sure why you want to do it yourself if you are not a mechanic. Air con maintenance and repair is is one job to leave to the experts.
Is there no air-con shop near you with a better price ? I suspect you have been quoted for a new compressor. They are not cheap items, but you can find cheaper on the internet, if you can get an air con shop to swap them out for you.
Old Jun 9, 2011 | 04:55 PM
Nevette's Avatar
Welcome to the forum and best of luck with your compressor. When you can, tell us more about your Jag.and maybe post a picture or two. Have a good time here.
Old Jun 9, 2011 | 05:11 PM
jjborst1's Avatar
It has no refridgernt in system It doesnot look complicated and I can get a compressor for a third of the price I was quoted.I just want to make sure I do it right.
Old Jun 9, 2011 | 07:35 PM
A warm welcome to you JJ.
This is the welcome section, please do not start multiple posts asking the same question.
If you need technical advice the relavant section for your vehicle will yeild the best results.
Old Jun 10, 2011 | 07:19 AM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
This section is for an intro if you have a question go to the section for your car. We have a lot of talented people to help.
Old Jun 10, 2011 | 08:24 AM
Doug's Avatar
It'll be pretty easy since there's no freon in the system to deal with.
Two bolts hold the compressor in at the fron and two hold it in at the rear. Remove bolts, wires, and bolts...and lift it out.
You'll have to remove the cruise control bellows to reach the rear bolts.
Old Jun 10, 2011 | 03:45 PM
jjborst1's Avatar
Thanks It didnt look complicated
Old Jun 10, 2011 | 04:02 PM
motorcarman's Avatar
The Harrison A6 compressor is the same one used by GM cars since the 60s??
Make sure you get the compressor with METRIC threads and not the standard ones.
You can use the standard one but you will have to swap out all the mounting hardware to avoid ruining the threads.
Good luck with the swap.
bob gauff
Old Jun 10, 2011 | 04:20 PM
jjborst1's Avatar
Thanks for the info ..............JJ
aholbro1
Dec 29, 2024 06:46 PM
mbergen
Oct 23, 2019 10:26 PM
danke
Mar 3, 2016 10:57 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Greg Reed
Sep 9, 2015 07:20 PM
