New member with XK battery charging
Old Dec 24, 2017 | 08:04 AM
Ruairidh's Avatar
Post New member with XK battery charging
First post rather than new.
2013 XK convertible had a flat battery. The manual was really unclear as to charge the car, the positive terminal was early enough to find but negative ?no clue.
Used a YouTube search and discovered that you use the exhaust as the negative but in addition as the engine is 5L, a guy in the car park said I needed bigger cables. As I was luckily outside a car store, Halfords, Waterlooville in Uk, I bought some for a 4.5l car and they worked first time.
Unfortunately it looks like the temperature sensor is now not working so the heating is not working. Maybe a fuse issue. Any Thoughts?
Any thoughts
Old Dec 24, 2017 | 09:40 AM
Welcome to Jaguar Forums Ruairdh,
I've moved your other post to the X150 section you can find it here https://www.jaguarforums.com/forum/x...arging-194224/
Old Dec 24, 2017 | 09:52 AM
Old Dec 24, 2017 | 10:49 AM
Welcome to the forum Ruaridh,
Follow this link https://www.jaguarforums.com/forum/xk-xkr-x150-33/ to the X150 forum for help, advice and information.
You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/
Enjoy the forums.
Old Dec 24, 2017 | 02:58 PM
Daf11e's Avatar
Welcome aboard.
Old Dec 24, 2017 | 03:03 PM
o1xjr's Avatar
Welcome to the forum.
Old Dec 24, 2017 | 03:31 PM
NBCat's Avatar
Originally Posted by Ruairidh
...Unfortunately it looks like the temperature sensor is now not working so the heating is not working. Maybe a fuse issue. Any Thoughts?
If the battery is 'flat', you should disconnect the terminals and use a battery charger to bring it up to a full charge.
Quite often, many of the mysterious electrical 'faults' discussed across these forums are mainly caused by a failing or weak battery.
After the battery is fully charged and the charger disconnected for at least ten minutes, use a voltmeter to check the voltage across the terminals. If the voltage is less than 12.5 volts, the battery must be replaced.
Old Dec 24, 2017 | 09:32 PM
Welcome to the Forums.
Old Dec 25, 2017 | 01:16 PM
welcome to the forum!!
LoveHerTopless
Feb 8, 2018 11:47 PM
lcyoung
Jul 11, 2009 09:59 PM
Alwann
Jan 29, 2009 12:37 AM
nemesis1109
May 13, 2008 05:08 AM
Big Ron
Feb 5, 2008 01:13 PM
