Quickly draining battery. help please.
Old Apr 25, 2021 | 08:45 AM
jackking jag's Avatar
Default Quickly draining battery. help please.
I have a 2004 XJ6 SE and the battery is being drained by a mysterious permanent 4 amp load on the circuitry. I disconnected the battery and checked that is was maintaining the charge and it is fine. When the battery is connected (ignition off) the voltage "counts down" at a rate of 0.1 volt per second. I connected my multimeter between the Positive terminal and thee connection lead and it shows a current flow of over 4 amps I've left the battery disconnected while I investigate. Has anybody got any ideas? Thanks in advance for any clues you can give me.
Old Apr 25, 2021 | 09:10 AM
Hello,
I'm sorry to read about your battery drain. Someone will be along shortly to direct you to the correct section where you can find help and advice about that.
Welcome to the forums form ElinorB.
Old Apr 25, 2021 | 10:09 AM
Welcome to Jaguar Forums jackking jag,
Old Apr 25, 2021 | 04:25 PM
Daf11e's Avatar
Welcome aboard.
Old Apr 25, 2021 | 04:35 PM
welcome to the forum - enjoy!!!!
Old Apr 25, 2021 | 05:21 PM
Welcome to the forums jackking jag,
Follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Apr 25, 2021 | 10:25 PM
Welcome to the Forums.
Old Apr 26, 2021 | 02:57 AM
o1xjr's Avatar
Welcome to the forums.
Paulrwalkington
Oct 15, 2017 12:57 AM
hlgeorge
Dec 3, 2016 01:43 PM
Compounder
Jan 13, 2015 05:58 PM
P4nth4
Feb 18, 2010 06:04 AM
