"006 S Type Bluetooth
Old Mar 24, 2013 | 02:18 AM
Peter.Munton's Avatar
Exclamation "006 S Type Bluetooth
Hi Peter Munton, Dublin, Ireland here.I have just purchased a 2006 S Type 3.0 also a Sony Xperia J mobile phone I can pair them no problem but the address book does not transfer to the car.I had an old phone and I could transfer the address book so I know I am using the correct method. So to my Question, can the bluetooth software be updated, or can an upgrade bluetooth module be purchased
Old Mar 25, 2013 | 11:26 AM
StanboyUibigh's Avatar
Default bluetooth
are you pairing with, ##3#*#
Old Mar 25, 2013 | 01:07 PM
Default Bluetooth module
Yes I have tried that I have followed all instructions in the manual
Old Mar 25, 2013 | 01:57 PM
police666's Avatar
the are a few threads on here about this, from memory (i'm to lazy to search, thats your job) i think it is something to do with the version of bluetooth your phone uses v the type of bt the jag has, latest phones use v3, & v4 i think your phone has v2.1, not sure about the jag but suspect v1.?
This is from memory but a good google should clarify things.
Old Mar 26, 2013 | 07:13 AM
so you get the phone accepted, right? THEN it is important to switch ignition off and leave phone in the car ie connected for at least 6 minutes, the phone auto disconnects after this time. try it?
Old Mar 27, 2013 | 08:43 AM
I Have followed all the instructions in the manual including switching off the engine for at least 6 minutes
Old Mar 27, 2013 | 09:40 AM
JagV8's Avatar
If a Search on bluetooth didn't get you the answer then you're a pioneer with a problem no-one else has / solved.
Old Mar 28, 2013 | 02:23 AM
Thank you for your help.
Sorry I don't seem to have been very clear I can pair my phone and I can use the phone via the keypad in the car but the phone book does not transfer to he car.
My car is a 2006 S type 3.0 petrol with an upgraded sound system listed in the log book as a luxury model.
Old Mar 28, 2013 | 05:45 AM
JagV8's Avatar
I got all that. You either are a pioneer or you're not and it seems from what you say that you are. If you figure it out then others may benefit.
Old Mar 28, 2013 | 06:31 AM
.......... 2006 S Type 3.0 also a Sony Xperia J mobile phone I can pair them no problem but the address book does not transfer to the car.............
Jaguar BT Connectivity Centre doesn't list your Xperia J but see the line I've highlighted with the red arrow against the Sony Xperia X1:
Connectivity with newer phones in older Jaguars is becoming more difficult. Even with the fewer phones that can connect, Address Book sync is often unavailable. As an example, my Samsung Galaxy will pair in my 2005 XK8 but the Address Book will not sync.
I think you could be on a loser trying to progress this issue.
Old Mar 28, 2013 | 07:20 AM
JagV8's Avatar
Oh dear. And good luck getting the phone maker to fix their new buggy code!!
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
