03 S-Type R "HELP" !!!A/C Problem!!!!!
Old Jun 21, 2008 | 01:16 PM
Mike E's Avatar
Default 03 S-Type R "HELP" !!!A/C Problem!!!!!
Hi everyone OK this is my problem I got a 2003 S-Type R my front left and right and the rear back vents is blowing hot air when I turn on the A/C and the front middle vent is a lil cold but not as cold as it should be. So I took it to a shop after it got the A/C recharge it was doing the same thing so I took it to another shop that work's on Jags they put it on the machine and told me it was the heater valve and auxiliary water pump so I got those change and it still does the same thing. PLEASE HELP me if you had the same problem know what it is Thanks
Old Jun 22, 2008 | 03:45 PM
FactoryJaguarTech's Avatar
Default RE: 03 S-Type R "HELP" !!!A/C Problem!!!!!
Could be the matrix box, the evap temp sensor or the evaportor, or the climate control module. Without physically being there, impossible to tell. Best bet, especially being an R, is to go to the dealer and at least get it diagnosed properly. Then decide what you are going to do to fix it.
Old Jul 3, 2008 | 02:43 PM
Mike E's Avatar
Old Jul 13, 2008 | 03:47 PM
Mike E's Avatar
http://www.jaguarforum.co.uk/viewtopic.php?t=2600
anybody know what it is?
Mike E's Avatar
Old Jul 14, 2008 | 06:00 AM
So have you checked for corroded connections as suggested in your link?
Old Jul 14, 2008 | 06:54 PM
Mike E's Avatar
yeah i did what it said and notthing happen i dont know what it is it should of work because i replace that part im just trying to find a cheaper way out than taking it to a shop
Old Aug 8, 2008 | 12:07 AM
mjbedingfield's Avatar
Have you tried taking your air off AUTO by turning the fan dial.
I have an 04 S and live in Hawaii... so I never turn the air off.
I had a problem with it blowing hot air when it would start up but would cool down after a time
took it to the dealer in Honolulu and they could not find a problem.
of course after the warranty was up it started to do it all of the time and lasted for longer periods.
I turned the fan dial which turns the auto off... killed the engine and started it and god bless the jag god there was cold.
Occasionally I do go back to auto and it works for a time...
Mine I am sure is in the climate control... but I'm cool;-)
good luck...
Old Feb 4, 2009 | 01:51 PM
Mike E's Avatar
Still blowing Mix Air anyone have the same problem and got it fix?
Old May 1, 2009 | 09:46 PM
Mike E's Avatar
Anyone?
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Dicque
Sep 19, 2015 12:53 PM
jehart49
Sep 12, 2015 05:36 PM
user 652867429824
Sep 5, 2015 12:53 PM
OkieTim
Sep 2, 2015 12:48 PM
