2000 S-Type Won't Start After Sitting In Storage
Old Feb 5, 2019 | 05:22 AM
snooktarpon's Avatar
Default 2000 S-Type Won't Start After Sitting In Storage
My 2000 S-Type 3.0 has been sitting in storage (indoors, climate controlled) for about 1 year. I just put in a new battery (the previous battery died about 1 year ago). It was low on gas so I add about 5 gallons of fresh gas. The starter is cranking but will not start. Any ideas on how to get it started?
Old Feb 5, 2019 | 11:19 AM
kr98664's Avatar
1) Make sure your new battery is fully charged. Most new batteries are only partially charged when purchased. Connect it overnight on a charger with at least a 10 amp output. Don't blow this off, thinking the starter cranking speed is good so therefore the battery must be properly charged.
2) Observe the PATS indicator light on the dash, at the base of the windshield. This is for the security system, which may have inhibited pump operation as a precaution. Here is how it's supposed to behave if all is good:
First, lock the car with the key fob. Press the lock button a second time to set the alarm system. The horn should chirp once. Watch the little red light. It should flash once every 3 seconds or so (not sure of the exact time) to show the system is armed. Now press the key fob unlock button twice to unlock all the doors. The red light should go out. Now hop in the driver's seat and turn the key to RUN (Not start yet). The red light should come on solid ONCE for about 3 seconds and then go out. If it flashes anything after that, you've got a stored fault.
3) Check the fuel pressure with a mechanical test gauge. There is a test port on the injector fuel rail. It's easy to access, IIRC. I forget the exact value you should see, maybe around 45psi? You don't even have to crank the engine for this. Just turn the key to RUN and the pump should operate briefly to precharge the lines.
4) If the fuel pressure is low, listen for the sound of the fuel pump. You may have to remove the bottom cushion of the rear seat to hear it.
The most likely scenario is your fuel pump has died. There are many cases in this forum of pumps giving up the ghost after long periods of inactivity. But run through the quick checks given above before convincing yourself the pump itself is the culprit. Let us know what you find and we can help with further steps to isolate the issue.
Old Feb 5, 2019 | 06:13 PM
abonano's Avatar
Plus one on the seized fuel pump.
Old Feb 7, 2019 | 04:46 PM
Karl, thanks for the detailed response. The battery is fully charged and still nothing. The PATS indicator light is working just as you described so no faults. So I'm going to get a fuel pressure tester. I found a schrader valve and attached a photo below. Is this the fuel pressure valve?
In addition, I removed the bottom seat and found the fuel pump on the passenger side. There is sticker that states Ford XW4U-9H307-AB. Googling it didn't really list any replacements. Then found some affordable pumps at Autozone: https://www.autozone.com/external-en...r&model=jaguar
So will these work? I'm not sure what the difference is between the difference pumps listed.
Since this is just a Ford part, are there other affordable (and reputable) places to order a replacement pump?
Old Feb 7, 2019 | 05:04 PM
NBCat's Avatar
Here are the fuel pressure specifications for the X200:
Old Feb 7, 2019 | 05:06 PM
NBCat's Avatar
More than likely the fuel pump is seized. Follow the test procedure outlined in the Workshop Manual. If you don't have the Workshop Manual, you can download it here:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Old Feb 7, 2019 | 06:37 PM
Thanks NBCat!
I have the JTIS on CDROM but I haven't used it in years. I tried to install it today on my Window 10 PC and it wouldn't run. I was planning on rebuilding an old PC just to run JTIS so you saved me some time.
Old Feb 7, 2019 | 06:39 PM
I would still like to know where to buy affordable replacement parts and/or if the Autozone fuel pump would work.
Old Feb 7, 2019 | 08:32 PM
After doing some research, it looks like I just kit a kit on eBay which has the motor, filter, and O-rings. Here is one auction: https://www.ebay.com/itm/US-Motor-Wo...0ekE:rk:9:pf:0
Is this a good solution versus replacing the whole pump?
Old Feb 7, 2019 | 11:10 PM
kr98664's Avatar
​​​​​​ So I'm going to get a fuel pressure tester. I found a schrader valve and attached a photo below. Is this the fuel pressure valve?
Yep, that's where the fuel pressure tester is connected.
Old Feb 7, 2019 | 11:18 PM
kr98664's Avatar
Several forum members have had good results with similar kits. However, I'd be a bit hesitant to install no-name Chinese parts, especially with something so critical.
Given a chance to spend your time and money, I'd suggest a name brand such as Carter or Delphi:
https://www.rockauto.com/en/catalog/...fuel+pump,6256
Old Feb 8, 2019 | 02:48 AM
Ducmon's Avatar
Hi I think that this is the answer for your problem.
He found out which Ford fuel pump fits.
https://m.youtube.com/watch?v=Y5r1OMxA51s
Old Feb 8, 2019 | 09:41 AM
I did see that video. I agree with kr98664 about ordering cheap Chinese parts from eBay. I didn't want to go that route. So I'm going to get the Delphi FE0420 kit (motor, O-ring, strainer) on Amazon for $82. Thanks everyone. I'll post an update when I'm installed the kit.
I forgot to mention: I didn't bother measuring the fuel pressure because I had no pressure in the lines. When I opened the Schrader valve, nothing happened except a little fuel just barely leaked out.
Old Feb 8, 2019 | 09:43 AM
NBCat's Avatar
Before ordering any parts, complete your diagnosis by checking the electrical circuit as well. If that's functioning correctly, then replace the pump.
Old May 24, 2019 | 03:44 PM
Update: Life got in the way so I haven't worked on my Jag until this week. I had ordered the Delphi FE0420 fuel pump kit back in February. On Sunday, I pumped out all the old gas and I finally removed the fuel pump. There was a small flat rectangular filter at the bottom of the pump assembly that was deteriorated and all the pieces were at the bottom of the tank. So I spent 10 minutes cleaning out the bottom the tank.
When I removed the pump, I noticed an external filter #XR817558 which I wasn't expecting. The filter exterior looked corroded as well as the rubber hose attached to it on one side. So I ordered a replacement filter along with the green gasket. I replaced the rubber hose at Autozone. I then installed the Delphi kit (pump motor and 2 small filters). I inserted the fuel filter back in the tank and filled the tank with fresh gas. When I turned the key (before cranking), I could hear the fuel pump run for a few seconds. When I cranked it, it wouldn't start. I tried off and on for about 10-15 mins and no luck.
The next day, I went to Harbor Freight and purchased their fuel pressure gauge for $20. Before testing the fuel pressure, I tried to start it one more time and it started right up! Woo hoo!!!
Below are the before and after pics of my fuel pump:
Old May 24, 2019 | 08:01 PM
abonano's Avatar
Nice job. Glad all worked out.
Old May 27, 2019 | 07:00 AM
wydopnthrtl's Avatar
Thanks for the post. This is good posterity
Geoff's Jag.
Apr 18, 2018 12:57 PM
Jsnyder0828
May 8, 2015 01:08 PM
AntXJ
Mar 26, 2015 03:57 AM
AntXJ
Mar 20, 2015 03:06 PM
Joe15555
Jan 1, 2012 09:46 PM
