2000 v8 Starter rebuild parts?
Old Mar 26, 2013 | 10:30 AM
x.l.r.8's Avatar
Default 2000 v8 Starter rebuild parts?
So being cheap on parts, and from an era where your repair instead of replace (read OLD!), I thought I would pop my starter out and see why it's a 50/50 shot on starting, thought it may be extended electrical but the solenoid made the right sounds, jumping it from another car or charging the battery fully meant it started. But there was never an in-between, like the starter dragging. Turns out the copper contacts from the plunger are worn, one wafer thin on an angle, I cleaned it and realigned the contacts and I am about to put it back together but a coffee break had me looking for a replacement just in case this does not work. The plunger is a common part but does anyone in the trade know if the solenoids are also the same, at least the contacts as I'm sure it would be a cheaper avenue to go down. Here's the list I got for the plunger
Plunger for Denso 1.2KW & 1.4KW OSGR Starters
Part Numbers
NIPPONDENSO
053660-7150, 053660-7151
Applications
DODGE Car & Lt Trk
RAM PICKUPS 8.0L(488) V10 1999-2003
JAGUAR Car & Lt Trk
S-TYPE 4.0L 2000
VANDEN PLAS 4.0L 1998-2000
XJ8 4.0L 1998-2000
XJR 4.0L 1998-2000
XK8 4.0L 1997-2000
XKR 4.0L 2000
TOYOTA Car & Lt Trk
CAMRY 2.2L 1998-2001
RAV4 2.0L 2001-2003
RAV4 2.4L 2004-2005
CHRYSLER
56027703AB, 56027703AC, 56027703AD, R6027703AC
DENSO FIRST TIME FIT
280-0378
FORD
96JV-11001-AC
JAGUAR
LCA-1850AB
NIPPONDENSO
128000-8430, 128000-8431, 228000-5090, 228000-5091, 228000-5093, 228000-6270, 228000-6271, 228000-6272, 228000-6273, 228000-7430, 228000-7432, 428000-0990, 5-228000-079
TOYOTA
28100-74270
as you can see it's a common enough part!
Old Mar 26, 2013 | 01:49 PM
x.l.r.8's Avatar
I can answer myself now I'm in town ( any excuse to try it out) and $4.95 gets a set of ram contacts, add $5 for a new plunger or the same for a Jaguar $29.95. Mines perfect now but I think it's a cheap spare to have on the shelf.
Old Mar 26, 2013 | 01:54 PM
plums's Avatar
Do you have the part number for the ram contacts?
Old Mar 26, 2013 | 08:32 PM
x.l.r.8's Avatar
I don't now,, but an e-bay search turns them up. I'll look tomorrow when I'm not on dial up
Old Mar 27, 2013 | 07:28 AM
x.l.r.8's Avatar
Applications
AC Delco
323-1051, 336-1428, 336-1541, 336-1568, 336-1573, 336-1624, 336-1628, 336-1633
Acura
31200-P54-003, 31200-P72-A01, 31200-P73-A01, 31200-P75-901, 31200-PR7-J01, DX51D, DXD1V, DXD1W, DXDR6, DXDRJ
Carrier Transicold
29-39135-00
Chrysler
04609346AD, 4467185, 4557284, 4609010, 4609346AD, 4609703, 4686104, 4686111, 5234648, 53005984, 56004757, 56027702, 56027703
Cummins
3675153RX
General Motors
94854717, 94855154
Honda
06312-P03-901RM, 31200-P03-901, 31200-P03-904, 31200-P54-003, 31200-P73-A01, 31200-PM3-J01, 31200-PM3-J02, DX4R4, DX4RE, DXDR6, DXDR7, DXDRJ
Isuzu
2911230000, 8943446930, 8943718330, 8943718331, 8943770240
Kubota
19013-63012, 19013-63013
Nippondenso (Denso)
128000-7010, 128000-7390, 128000-7500, 128000-7560, 128000-7710, 128000-7712, 128000-7713, 128000-7714, 128000-7715, 128000-7810, 128000-8030, 128000-8031, 128000-8350, 128000-8360, 128000-8400, 128000-8410, 128000-9710, 128000-9720, 128000-9730, 128000-9740, 128000-9750, 128000-9751, 128000-9752, 128000-9870, 228000-0360, 228000-0361, 228000-0363, 228000-0820, 228000-0821, 228000-0822, 228000-0823, 228000-0830, 228000-0831, 228000-0832, 228000-0833, 228000-0890, 228000-0900, 228000-0901, 228000-0902, 228000-1070, 228000-1071, 228000-1560, 228000-1700, 228000-1800, 228000-2050, 228000-2060, 228000-2061, 228000-2062, 228000-2500, 228000-2890, 228000-2940, 228000-2960, 228000-3010, 228000-3011, 228000-3012, 228000-3013, 228000-3014, 228000-3020, 228000-3021, 228000-3023, 228000-3024, 228000-3030, 228000-3032, 228000-3033, 228000-3210, 228000-3211, 228000-3260, 228000-3390, 228000-3391, 228000-3392, 228000-3393, 228000-3400, 228000-3401, 228000-3402, 228000-3403, 228000-3990, 228000-3991, 228000-3992, 228000-4000, 228000-4001, 228000-4370, 228000-4371, 228000-4372, 228000-4390, 228000-4391, 228000-4650, 228000-4651, 228000-5490, 228000-5670, 228000-5680, 228000-6170, 228000-6172, 228000-6173, 228000-6280, 228000-6281, 228000-6282, 228000-6283, 228000-7200, 228000-7201, 228000-7250, 228000-7260, 228000-7261, 428000-1550
Toyota
28100-01030, 28100-02050, 28100-02060, 28100-03020, 28100-03030, 28100-03070, 28100-03090, 28100-03100, 28100-08020, 28100-16130, 28100-16180, 28100-16220, 28100-16240, 28100-16270, 28100-20553-71, 28100-35060, 28100-35060-84, 28100-35090, 28100-64170, 28100-66040, 28100-66060, 28100-74070, 28100-74090, 28100-74100, 28100-74130, 28100-74140, 28100-74230, 28100-74240, 28100-74260, 28100-74280, 28100-74290, 28100-74291, 28300-22003-71
Old Mar 27, 2013 | 08:52 PM
clubairth1's Avatar
Community Influencer
Don't lose a starter much anymore at all? How many miles on your car?
Since everything went to fuel injection years ago I have not replaced a starter.
Old Mar 27, 2013 | 09:44 PM
plums's Avatar
Those particular parts could be considered to be wear parts because the heavy amperage arcs across the contacts and burns them. Crank the car 1000 times and the arc happens 1000 times. Fuel injection or not.
Old Oct 3, 2014 | 08:33 PM
plums's Avatar
Default contact identification
Can someone identify the correct contact styles from the picture below?
I am thinking 1 each of the first and second from the left.
bdboyle
Sep 16, 2019 05:58 PM
King Charles
Apr 16, 2017 11:10 AM
AntXJ
Sep 24, 2015 06:30 PM
Tim Goz
Sep 17, 2015 09:11 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
