2002 3.0 No Start
Old Dec 22, 2013 | 08:27 AM
pnecoechea's Avatar
Default 2002 3.0 No Start
I've been having a problem with my jaguar when trying to start it where the starter will turn, but the car will not start until about 8 to somtimes 25 tries. I just replaced the*fuel*pump, sender and fuel filter and it worked for a day than on the second day it went back to taking awhile to start which makes me know something else is wrong.*Check*engine*light*is on and its running lean in bank 1 and 2 because of a vacuum leak that is getting fixed but i dont think that is the case. Sometimes when it does fire up after a few turns, it seems to want to stall making me turn key back to off. After a few times it than fires right up running great. When running awhile if I turn*the*engine*off and run in a store it fires right back up. It also seems to give me problems after it sits for awhile. SOMEONE PLEASE HELP!!! Shop seems to be clueless and has me worried....Sometimes when I pull the key out its HOTT!!!
Old Dec 22, 2013 | 02:42 PM
JagV8's Avatar
A vacuum leak can make it very hard for the computer to run the engine. Start by fixing it.
Old Dec 23, 2013 | 05:24 AM
pnecoechea's Avatar
Thank you jagv8, but I don't know anything about vacuum how can I know if it's working properly? Or fix it? What do I have to do? The mechanic supposed to fix it told that he will check it after the holidays. Can you tell me pls. .. tks
Old Dec 23, 2013 | 05:27 AM
JagV8's Avatar
There are a lot of threads about leaks but you sound to be short on experience. Have a read and see if you think you can continue but if in doubt it's likely wise to get a tech to fix it. Realise you could easily make things worse if you work without appropriate knowledge and care.
Old Dec 26, 2013 | 12:15 PM
pnecoechea's Avatar
Well my vacuum leak is fix, it was just a cracked connection, now what's? I still I have problems to start my jag.
Happy holidays to everybody.
Old Dec 26, 2013 | 03:23 PM
Mikey's Avatar
What year car, which engine? (Please put these in your sig)
What codes are present?
Old Dec 27, 2013 | 05:48 AM
pnecoechea's Avatar
2002 s type 3.0
I don't have any code or warning lights on the dashboard.
Thank you for your help sir.
Old Dec 28, 2013 | 02:51 AM
JagV8's Avatar
If you want to DIY you've got a lot of reading to do. Start with the stickies here and get JTIS. You don't sound to be in the area of an easy DIY fix.
Old Jan 10, 2014 | 07:28 AM
pnecoechea's Avatar
Thank you for your help. I appreciate it.
I fixed my jaguar s type. My problem was a bad relay.
Thanks again.
way2far
Aug 31, 2022 09:26 AM
cissdm
May 3, 2016 06:02 AM
Dicque
Sep 19, 2015 12:53 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
Numwen
Sep 6, 2015 12:30 AM
