2003 S type R Head Gasket Blown
Old Aug 29, 2013 | 10:39 AM
AlBentley's Avatar
Default 2003 S type R Head Gasket Blown
Hello,
I'm new to the forum so please forgive me if this information is out there. I haven't found it by searching. I need a copy of the repair manual or procedure with torque specs. I need to replace head gaskets this weekend and get this baby back on the road. Any help is appreciated.
Al
Old Aug 29, 2013 | 10:53 AM
JagV8's Avatar
Grab JTIS, free on here. It's the workshop manual.
Old Aug 29, 2013 | 11:15 AM
abonano's Avatar
Welcome.
Is this STR a new purchase or owned/driven by you already. I only ask if it's recently been purchased this way you may be in for more surprises down the road.
+1 to JTIS.
Good Luck!
Old Aug 29, 2013 | 12:33 PM
tbird6's Avatar
How did the head gasket go?
The entire engine is Aluminum and very prone to warping if overheated and that is by far the most common way to blow a head gasket.
I always surface the heads when replacing a head gasket. It's just good insurance.
Old Aug 29, 2013 | 06:58 PM
AlBentley's Avatar
It is a new purchase. I am assuming the car overheated since it had a split heater hose and would not hold water...
Old Aug 29, 2013 | 08:09 PM
AlBentley's Avatar
I'm Having issues. Does anyone have a link to a JTIS that will work on windows 7 64 bit?
Old Aug 29, 2013 | 09:31 PM
clubairth1's Avatar
Community Influencer
Yes there are some threads on that. What I do is run virtualXP. It's a free download from microsoft. I then install the JTIS on the virtual XP system. Works fine but people have reported problems and just purchased a disc off Ebay! So cheap at less than $10.
Old Aug 30, 2013 | 01:28 AM
JagV8's Avatar
You can instead get an updated version cheap that's in PDF.
Old Sep 9, 2013 | 07:15 PM
AlBentley's Avatar
Okay. I have a manual now however, the pdf shows a motor with a VCT and the motor I have does not have a VCT phaser. Are the head removal and torque sequences the same?
Thanks for all the help guys.
Al
Old Sep 10, 2013 | 07:19 AM
JagV8's Avatar
Earlier than about 2005/6 STR don't have VCT. I think just ignore VCT stuff.
Old Sep 10, 2013 | 07:32 AM
WhiteXKR's Avatar
Originally Posted by AlBentley
Hello,
Al
It is common to drop valve seats on this engine also during a severe overheat....do not assume the head gasket is the only problem.
Old Sep 26, 2013 | 12:42 AM
howie713's Avatar
I just ran in to the same problem heat line connector busted on my wife while driving not sure how long it took until she noticed it was over heating. Replaced the broken line connector filled up coolant and was back on the road about 20 miles later it started blowing white smoke out the tail pipes. I am going to start tearing into it tomorrow. Anyone have suggestions/ideas on what I need to be looking for while I am this far in (as far as other parts that may have failed)? Any suggestions? Does anyone know part #'s and a good place to get the head gasket kit?
ClassiXtype
Oct 22, 2023 05:29 AM
Jaguila
Sep 5, 2015 06:16 PM
big d
Sep 3, 2015 07:37 PM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
