2004 s series HELP...
Old Jun 7, 2018 | 05:44 PM
pac72's Avatar
Default 2004 s series HELP...
found a maybe steal on a 2004 s series 6cyl automatic,110 k miles it runs but doesn't move... besides trans failure anything I can check out that these are known for ? we already have 2004 s series so maybe just a parts car for us.. they sound ready to move it .. asking $800 , but im thinking of offering $500 and show up w a car dolly...body and interior look good from the few pics ive seen..
anybody with more knowledge care to chime in ?
Old Jun 7, 2018 | 11:00 PM
kr98664's Avatar
What happens when you put it in gear and try to drive away? Does the engine just rev as if still in P or N? Or does the engine bog down and maybe the transmission groans?
Also, watch the P, R, N, and D indicators at the base of the shift lever. 2003+ cars are notorious for the bolts backing out that secure the shift cable to the transmission. When that happens, you can freely move the lever but nothing else happens. The P, R, N, and D indicators are feedback from the transmission innards, NOT the shift lever itself. If the lever moves but the indicator lights do not respond, the cable has most likely come loose.
Can you move the lever out of P? There's an interlock that must release first. If it won't release, you can move the lever about halfway to R but no further. In that case, it could be a bad solenoid or the lack of a required input.
Old Jun 7, 2018 | 11:01 PM
abonano's Avatar
6hp26 transmission.
Maybe low on fluid but probably means trans is toast anyway. You can try and find one and roll the dice at a wrecking yard.
Otherwise these trans are very expensive to rebuild.
Old Jun 8, 2018 | 08:09 AM
NBCat's Avatar
Check under the vehicle for leaks from the gearbox as it may just be low on fluid.
Use the search function for this forum as there are several threads that discuss items to look for when considering an S-Type purchase.
Old Jun 8, 2018 | 05:08 PM
pac72's Avatar
thanks on the replys guys, the seller says her ex bought it like it is, so no real input from her...id actually like to do a Saturday night special smallblock chevy transplant into it...is an ojdschool 350 chevy transplant a workable deal ? been around stockcars for years so the engine mounting etc is no issue..im thinking about the electronics..and ill want ac too
Old Jun 9, 2018 | 05:31 AM
joycesjag's Avatar
Good luck! Post pictures of your progress.
Old Jun 10, 2018 | 12:32 PM
clubairth1's Avatar
Community Influencer
Don't forget that there are 2 small bolts that can loosen and even fall out. These hold the shift cable to the transmission. Be SURE when you are under the car to look and check these 2 small bolts.
Old Jun 10, 2018 | 06:46 PM
pac72's Avatar
well we decided to pass on it..as we really don't have the room to store it
DreWRoolZ
Apr 14, 2014 11:02 AM
myronc
Mar 27, 2014 03:37 PM
Mopoor
Dec 17, 2012 09:00 AM
alabbasi
Nov 1, 2012 10:59 AM
ryawee
Feb 26, 2011 07:33 PM
