20inch wheels help...
Old Mar 5, 2014 | 01:47 PM
jpvd's Avatar
Question 20inch wheels help...
Hi All
Looking at some Jaguar Orona Alloy Wheels, 20inch from an XJ. Tyres are 255 35 20. Wheels are 9J ET49.
Will these fit on my 2000 plate s type v8, without any modifications?
Lovely looking wheels, but don't want to commit if they won't fit. If anybody has any photos of 20's on s type too, that would be great.
Thanks in advance!
Old Mar 5, 2014 | 09:18 PM
Bad Cattitude's Avatar
As long as the XJ is 2004 or newer they both show the same specs except center bore. The XJ's is 74.1 vs the S-Type @ 63.4.
Bolt pattern | Stud Pattern : JAGUAR Bolt patterns
Old Mar 6, 2014 | 03:30 AM
jpvd's Avatar
93 views and only one response.... I've checked up and the wheels sizing is exactly the same, as it the centre bore.....therefore they should fit, although i am wondering if 20's are really a good idea on british roads...
Old Mar 6, 2014 | 06:46 AM
Michael Star's Avatar
I don't know about British, but I know even on the smooth roads here in the states 20s will make you feel the road a lot more.
Old Mar 6, 2014 | 09:51 AM
JagV8's Avatar
They'll be horrid.
BTW, Your location doesn't appear to show UK.
Old Mar 10, 2014 | 04:49 AM
cat_as_trophy's Avatar
+1 on that ... though I'm not game to use words like "horrid" ...
Mine has 18x8 Mercurys all round with, previously P Zeros, now Kumhos ... ride is firm but OK until you hit the really bumpy undulating stuff, when it may hit the bump stops ... result, a stiff jolt. My good friend's S-Type is identical but with split 20x9s at front and 20x10s at rear. Sitting on a "pile driver" (pun intended) has destroyed (IMHO) the excellent touring characteristics of his car.
More to the point, how narrow are these 20inch rims that you are only carrying 255 tyres? You do realize that increasing the rim diameter, then going lower profile to preserve the original rolling radius, adds not one iota of rubber on the road. However, increasing rim width does, for which you will sacrifice around 10% fuel efficiency on these figures. I would suggest you tread carefully and road-test widely. For me, I would go wider (275s are not the limit at rear) but not venture beyond 18 inch rims. I think the factory got it right (and well balanced) with the STR's 18x8.5s with 255s at front and 18x9.5s with 275s at rear ... then later with 19s.
Cheers,
Ken
Old Mar 10, 2014 | 06:11 AM
Cambo's Avatar
There was an STR here on the forum that had a set of 20" from an X350 fitted, the tyres had to be changed from the stock XJ size 255/35R20 to 255/30R20 because of rubbing on the wheel arches.
Old Mar 10, 2014 | 09:41 AM
Hello Cam ... Offsets?
If I recall correctly, the offsets for the 20" wheels I quoted are 40mm at front and 45mm at rear, but I can check this with my mate at weekend. I must repeat that the ride on 255/35s at front and 275/30s at rear, was a real shocker, and not for me.
Cheers,
Ken
Old Mar 10, 2014 | 04:37 PM
Cambo's Avatar
The OEM alloys from the X350 are 20x9 or 20x8.5 with ET49. If I've got time I'll see if I can find the pictures.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
Mbourne
Sep 14, 2015 09:21 PM
DustysSon
Sep 13, 2015 04:17 AM
