ABS
Old Mar 9, 2016 | 02:20 PM
Red Fox's Avatar
Angry ABS
I will try to keep this short, recently i replaced 2 of the parking sensors and stupidly allowed the battery to go flat. I then had an error message about the park brake until I read the manual and followed the correct procedure. All seemed well then until my wife drove the car and the ABS light came on as soon as the ignition light had settled and before the engine was started. When the engine was started ABS fault came up and Sid control unavailable.
I then decided to look at the rear wheel sensors, all look clean and undamaged but now I have a gearbox fault and it will only change up to 2nd gear! Any suggestions welcome.
Old Mar 9, 2016 | 03:01 PM
joycesjag's Avatar
Charge battery fully or replace with a new one.
Old Mar 9, 2016 | 03:03 PM
+1 make sure the battery is 100% before going further.
Old Mar 9, 2016 | 04:51 PM
Red Fox's Avatar
Thanks for the suggestions, battery is fine, it only went flat cos I left the keys in the ignition, my fault!
Old Mar 9, 2016 | 04:59 PM
It may be fine but is it fully charged?
Old Mar 9, 2016 | 08:27 PM
motorcarman's Avatar
HARD RESET!!!!!!!!!!!!!!!!!!!!!!
bob
Old Mar 9, 2016 | 08:59 PM
Gus's Avatar
Gus
If the hard reset does not fix the shifting problem I would check the shifter cable adjustment.
Gus
www.jagrepair.com
Old Mar 10, 2016 | 01:21 PM
Red Fox's Avatar
Norri, what I omitted from my short story was that I drove 25 miles to an independent jag man who deleted all faults showing, (ABS and low voltage) but as soon as I turned on the ignition, before even starting the engine the ABS light came on again!
Bob, How do I do a hard reset? Do i need a plugin tool?
Also can you throw any light on where or why does a load of steam emit from under the engine bay near the N/S front wheel? This has happened a couple of times within a few minutes of starting from cold.
Old Mar 13, 2016 | 03:31 PM
Red Fox's Avatar
bob
On my TomTom I can do a hard reset with a paper clip, I don't expect its that easy on the car?
Old Mar 13, 2016 | 03:39 PM
JagV8's Avatar
Use Search
It more or less is.
Old Mar 13, 2016 | 03:41 PM
Gus's Avatar
Gus
Link to hard reset.
Link.http://www.jagrepair.com/HardRestProcedure.htm
Gus
www.jagrepair.com
Old Mar 13, 2016 | 04:03 PM
Steam or smoke? It could be the Webasto heater if it was a cold morning.
Old Mar 13, 2016 | 04:17 PM
Red Fox's Avatar
Yes it was cold, it was steam although smelt a little fumy.
Is this a standard fitment?
Old Mar 13, 2016 | 04:23 PM
JagV8's Avatar
It's in the handbook. Or via Search, I expect. Even more details on the UK site.
Old Mar 14, 2016 | 06:15 AM
Red Fox's Avatar
Originally Posted by JagV8
Use Search
It more or less is.
I have put the battery on charge (just in case) and will try the Hard reset tonight. Cross fingers.
Old Mar 14, 2016 | 06:31 AM
JagV8's Avatar
I wonder if it going flat has in effect reset the (Webasto) fuel burning heater (FBH, aka FFH F=fired).
Old Mar 14, 2016 | 06:37 AM
Red Fox's Avatar
It beats me, I think its all witchcraft!
Old Mar 14, 2016 | 06:46 AM
JagV8's Avatar
On the UK forum, Victor would probably agree!!
hendogg8
Aug 28, 2024 10:13 AM
jfleming
XJ40 ( XJ81 )
Mar 2, 2016 01:46 AM
stevewiz
Feb 29, 2016 08:51 AM
Chuck Schexnayder
Feb 24, 2016 12:19 PM
Siebert22
Feb 22, 2016 03:23 PM
