Advice
Old Feb 12, 2017 | 03:27 PM
vela's Avatar
Default Advice
I have a 2000 Jaguar S type. It has 102+k miles. About 4 years ago it was involved in a hit and run. It was taken to a shop for body work and paint and unfortunately for reasons beyond reasonable explanation..there it sat. I recently reaquired it and was wondering if anyone could give me some advice to get it back to running status. Any helpful advice would be appreciated.
Old Feb 12, 2017 | 06:04 PM
abonano's Avatar
You might want to pass on this project unless you have tons of disposable income. It sat unused for years for a reason. If it has the V6 then maybe. If it has the V8, do yourself a favor and walk away, quickly...
Old Feb 12, 2017 | 06:27 PM
vela's Avatar
I was the owner then and now. It sat not because of any mechanical problems, but because of other non related factors. It ran great before it was damaged and the damage was cosmetic not mechanical. It also ran fine after. It just sat for 4 years.
Old Feb 12, 2017 | 07:15 PM
In that case, and probably the least $$;s involved.
Change the engine oil.
Drain, no idea how, the fuel tank, and replenish with fresh fuel.
Change the fuel filter.
Repakce the battery.
Turn the key, see what happens.
The V6 or V8 should not vary the above that I am aware.
If that fails to raise a smile, there is always a Plan B.
Old Feb 12, 2017 | 09:20 PM
abonano's Avatar
I bring up the V8 due to the known tensioner failure issues. Since the OP had this car before it sat that changes things for sure.
Fully agree with your advice above. Give it a whirl and fingers crossed.
Old Feb 13, 2017 | 04:36 AM
Agreed.
My S Type 3.4ltr had sat for 11 years, new battery, fresh fuel, topped up the radiator with "water", and drove it home, Jags are sooooo bloody reliable.
AND
Both our addresses are on file for the required JD delivery.
Old Feb 13, 2017 | 10:37 AM
Ducmon's Avatar
As it has been sitting there at the workshop for 4 years. I would add new tires to the shopping list as the old ones will have flat spots by now.
Old Feb 14, 2017 | 08:46 AM
vela's Avatar
Thank you gentleman. I appreciate your feedback and will keep you posted.
