air vent issues
Old Mar 8, 2013 | 03:18 PM
petestype07's Avatar
Default air vent issues
Hey everyone
So my climate system is making a popping sound from in the dash
Behind the vents . All air functions work currently . Heat and cold
Work great . and blows on both sides independently. Any ideas
Thinking maybe the actuators controlling the vent doors
Tianjin
Old Mar 8, 2013 | 03:24 PM
Jon89's Avatar
Exactly. You're hearing those pesky servo motors as they "hunt" for the correct position. There are a number of threads here on the forum for various ways to go about solving your problem. Search using "servo motor problem" as your key phrase and you should find yourself with plenty of reading to do....
Old Mar 8, 2013 | 05:21 PM
anyone have a "how-to" on checking which actuators may be bad without removing dash and all other stuff
Old Mar 8, 2013 | 05:54 PM
JagV8's Avatar
Yes. Use jag diagnostics to control each in turn. Otherwise, no.
Old Mar 9, 2013 | 01:21 PM
And that is at dealer only correct?
Old Mar 10, 2013 | 09:11 AM
JagV8's Avatar
No, anyone can buy the kit but hardly anyone except a rare indy does.
Old Mar 10, 2013 | 11:42 AM
Can I buy it ? How much we talking
Old Mar 11, 2013 | 08:24 PM
Sixx Dogg's Avatar
I just had my flaps and motor replaced at 1198.50 under warranty....
2006 stype sport 3.0 131 000km....
Old Mar 12, 2013 | 06:38 PM
clubairth1's Avatar
Community Influencer
Sixx Dogg: Can you post the part numbers? This is getting reported more and might become a common problem that needs fixing.
Old Mar 12, 2013 | 09:02 PM
Robinb's Avatar
Wow, that sounds like a pricey motor. Here are some notes I made from an earlier post on the subject.
(TSB00066, dated May 14, 2010)
A ticking or bubbling noise may be heard coming from behind the fascia / instrument panel when using the climate control system. The noise may be the result of one or more of the climate control blend door actuators giving incorrect position feedback to the climate control module, causing the blend doors to continually search for their correct position and causing the noise.
Action: Replace all four blend door actuators (about $16 each). Jag's time: 0.8 hours.
Parts:
XR8 57885 ..........Defrost vent / register blend door actuator Qty: 1
XR8 57886 ..........Footwell vent / duct blend door actuator Qty: 1
XR8 57887 ..........Instrument panel blend door actuator Qty: 1
XR8 57888 ..........Recirculation blend door actuator Qty: 1
Depends on what model of S-type, I guess, but from the above the cost would be around $200 excluding motor.
Old Mar 12, 2013 | 11:45 PM
Those parts numbers apply to an 07 3.0?
Old Mar 13, 2013 | 11:33 AM
Robinb's Avatar
Look here:
https://www.jaguarforums.com/forum/s...e-kinda-84471/
The bulletin says affected VIN range is N53000 - N91200 (2006 - 2008), but I had the same problem with my 2005 STR.
Old Mar 13, 2013 | 12:58 PM
tbird6's Avatar
Thanks for the part numbers and it looks like the motor is included with each actuator.
One last puzzle is Jaguar lists .8 hours to change all 4? In older cars changing even one actuator is usually hours and hours because the dash has to be removed. Especially when changing the defroster one.
Could Jaguar actually have made it easy to swap these out?
Still looking for a DIY guy who has done this repair and can walk me thru it.
Old Mar 15, 2013 | 10:43 AM
Sixx Dogg's Avatar
sorry about the delay...but I noticed you have the part #....904.50 in labour...
Old Mar 15, 2013 | 01:04 PM
TonyX's Avatar
Originally Posted by Robinb
Look here:
Robinb,
Can you comment on the difficulty of replacing the motors? The TSB you linked showed the process for one of the four. Thanks.
Old Mar 15, 2013 | 04:34 PM
Robinb's Avatar
Originally Posted by TonyX
Robinb,
Sorry TonyX, I have the problem but have not yet made the fix. I was just collecting info for the day when I go to the dealer (or an indie) for a quote. I did note, however, that the TSB specified the estimate and procedure was for all 4 doors, but that it was necessary to specify a "causal" part, whatever exactly that means.
Edit - after re-reading the TSB, it does look like the estimate might refer only to the instrument panel blend actuator door.
Old Sep 18, 2014 | 10:22 AM
tbird6's Avatar
On my 2005 STR I started getting a low tap, tap type noise from behind the dash. Only happens after the car is driven a while and the climate control slows down as the passenger compartment temperatures come under control. Very low in volume and I have to turn the radio off to hear it.
I followed the noise and it's in the passenger foot well area. This matched well with the description above of the blend doors hunting for the proper position. The actuator is not too expensive at about $50. Jaguar made it dead easy to change too! Just remove the glove box and you are looking at the actuator. 2 screws and uplug the electrical plug and it's out.
I got part number XR8 57888 as posted above (all marked with Ford part numbers too) and it is the correct part but it was assembled wrong and the actuator arm is about 100 degrees out of alignment. I can get another actuator and I am currently returning the one I have.
But the weird part is I put the old one back in and it's been a week or so and no noise of any kind!!
Could removing and reinstalling the actuator somehow reset it's position? I did cycle the power with the actuator hanging free so I could watch what it does when it's not hooked up to a blend door with the steel rod.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
OkieTim
Sep 2, 2015 12:48 PM
