aircon help please !!!!
Old May 10, 2018 | 06:54 AM
Jay Whitbread's Avatar
Default aircon help please !!!!
2004 s type, have replaced the heater valve,(3 way valve under the header tank) have replaced the climate control module, has been re-gassed yet still blows hot air on drivers side regardless, with this weather and the nature of my work i really need the aircon fully operational
any thoughts or suggestions ??? thanks
Old May 10, 2018 | 07:10 AM
Jon89's Avatar
Is your compressor operating properly?
Old May 10, 2018 | 07:27 AM
aholbro1's Avatar
Welcome to the forum, Jay. I hate to break it to you, but just because your water valve may be new...doesn't necessarily mean it actually functions properly. However, forget about that for now, and proceed straightaway to Karl's epic a/c troubleshooting thread. Follow his steps and it will systematically lead you to the problem.
https://www.jaguarforums.com/forum/s...ol-how-185002/
Old May 10, 2018 | 07:29 AM
Have you read kr98664's guide https://www.jaguarforums.com/forum/s...ol-how-185002/
Old May 10, 2018 | 01:00 PM
thanks yeah read the guide, got mega brainache, will start trouble shooting again tomorrow, will not be impressed if a brand new valve has failed the moment it was installed to the car, id allready checked relays and can hear the compressor kick in when activated the aircon, now im back of out to check a couple of other things before start cussing and telling the wife im of to buy an aston lol
Old May 14, 2018 | 09:02 AM
Kewpie's Avatar
I replaced everything, turned out it was some burnt wires in the harness. Now it blows ice cold
Old May 14, 2018 | 09:32 AM
jazzwineman's Avatar
It is likely that you have shorted out your CCM. Here is your best troubleshooting guide:
Tom in Dallas/Plano
Old May 15, 2018 | 10:09 AM
been through the guide and tried pretty much everything including a replacement ccm which made a slight improvement it now blows cold on the passenger side, so im suspecting replacement was faulty to, even my mechanic now scratching his head and said told ya to get a proper car not one of these fords in a frock lol
Old May 15, 2018 | 10:33 AM
Did he check the pressures in the system before doing his Tommy Cooper impression?
That would be good info to have. See the attached sheet to help.
File Type: pdf
Old May 15, 2018 | 11:58 AM
kr98664's Avatar
Um, how much of the guide have you actually tried? Many people complain it takes days just to read. You may have given yourself away...
Specifically, run the tests in post #2 of the guide to determine if the DCCV is responding properly to command inputs. You can easily do this yourself. You don’t need to pay a mechanic.
If that passes, drive the selected temperature down until LO is displayed. This puts the system in manual mode, and bypasses some of the automatic features. More details in the guide.
The guide was written for the average owner, with minimal tools and no professional help. Don’t just skip around, cherrypicking info and hoping for the best. As previously mentioned, don’t assume your DCCV is good just because it was recently replaced. Test that first and then go from there, based on the current symptoms, not what you think the problem may be.
Gavin Brown
Jun 1, 2019 04:41 PM
cbryantjr85
Oct 21, 2016 03:46 PM
rgp
Jul 4, 2014 05:48 AM
lost1
Jun 11, 2014 09:11 PM
nicks
Sep 12, 2008 12:09 PM
