Auxiliary water pump female connector plug
Old Sep 5, 2020 | 12:18 PM
V8Dave's Avatar
Default Auxiliary water pump female connector plug
Hello Guys . I damaged the female connector plug that clips into the bottom of the auxiliary water pump and I am looking to see if there is a replacement part or part number available. The car in question is a S-Type R 2004 . The only information available is that is a 2 terminal plug and it has a ford badge on it . Any help would be appreciated. Cheers
Old Sep 5, 2020 | 01:46 PM
kr98664's Avatar
Here you go:
https://www.motorcraft.com/content/d...-Book-2016.pdf
https://parts.ford.com/content/dam/f...il%20Final.pdf
Those two documents look to be the same basic catalog, but there may be some slight differences so I included both of them.
On your existing connector, is it just the locking portion that broke? Can you still fully insert the connector, even if it won't lock? If so, I'd be tempted to try locking it in place with a tyrap or similar, so as not to disturb the factory crimps. I think that would be a more reliable connection than splicing in a new pigtail.
Old Sep 5, 2020 | 02:02 PM
kr98664's Avatar
Look at the first page of 2-cavity connectors in either catalog. Does WPT-372 look similar? Both are also listed as 3U2Z-14S411-ATA. If you search online with either of those numbers, you will find many hits, both OEM and aftermarket. If close, but not quite right, try leaving off the suffix of that longer number and you should see similar connectors from that same basic series.
Old Sep 27, 2020 | 10:27 AM
V8Dave's Avatar
Default Burst coolant hose
Hello guys . I have a burst coolant hose on my S-Type R . I am not sure exactly what the correct name for this hose is or where it goes . I have managed to get a number off it but I am struggling to get a replacement. The number is 4H-23-9Y438-BC . Any help would be appreciated. Thanks
Old Sep 27, 2020 | 10:29 AM
NBCat's Avatar
Where is the burst hose located?
Old Sep 27, 2020 | 10:47 AM
V8Dave's Avatar
Hello . It’s located directly next to the temp sensor at the top front of engine. Cheers
Old Sep 27, 2020 | 12:03 PM
kr98664's Avatar
Can’t help with the hose, but did you ever find a replacement connector? If so, please post the part number to help out the next guy.
Old Sep 27, 2020 | 12:08 PM
V8Dave's Avatar
Hello . Yes I got an original plug from America . I ordered it on eBay ( Part number WPT- 372 ) or 3U2Z-14S411-ATA ) . Cheers
Juha Lystila
Jan 25, 2023 07:05 AM
L_T
Nov 23, 2017 11:57 AM
JigJag
May 12, 2017 05:41 PM
Jrp79
Feb 28, 2017 02:02 PM
Kewpie
Feb 20, 2016 05:50 PM
