Brake Caliper Issue
Old Aug 13, 2013 | 10:51 PM
YYZ's Avatar
YYZ
Default Brake Caliper Issue
Hi...The Drivers Side rear wheel locks.. "Park Brake Fault Error" on Dashboard..it clears...drivable...I think the Caliper needs to be replaced..not sure though...The wheel hub gets hot when this happens...does not happen all the time..intermittent...most of the time its ok...very bizarre ... I drive a Jaguar S-Type 3.0 V6 ...
Old Aug 14, 2013 | 02:06 AM
JagV8's Avatar
Pray it's your battery failing. Much cheaper and easier to fix than the EPB / motor, which may be the fault otherwise. How old is the battery?
Old Aug 14, 2013 | 08:30 AM
YYZ's Avatar
YYZ
I just recently bought the vehicle...not sure of the age of the battery...Gonna get it tested by a mechanic...Can any garage check a Jaguar Battery?...or do I need to go to a Jaguar Service Centre?...Thanks for your help...
Old Aug 14, 2013 | 10:24 AM
Mikey's Avatar
The EPB can be exercised manually to check it's operation. With the wheel removed, car securely placed on axle stands blah blah blah, have a helper apply and release the EPB while you monitor the free movement of the cable and caliper lever.
Old Aug 14, 2013 | 10:54 AM
tbird6's Avatar
If your car has seen salt then it's not bizarre at all! If fact very common to happen. Since it's only one side my bet is the cable or caliper needs replacing.
But follow what Mikey posted as you will need to just inspect everything while its operating.
If the battery needs replacing I like the Bosch version as it has the correct battery vent on both sides and comes with a plug for the side not used.
Old Aug 14, 2013 | 08:03 PM
YYZ's Avatar
YYZ
Thanks Everyone ...
Old Aug 14, 2013 | 10:41 PM
cliff328's Avatar
Default Agree with Tbird..
Last year, about this time, I replaced the battery in my 06 4.2 S. It
didn't seem to be causing any problems; however, at six years, I
felt a precautionary replacement was prudent. I went with Bosch
also; excellent warranty!
Until you get your problem fixed, get in the habit of depressing the
chrome parking brake switch on your console BEFORE you withdraw
the key after you have shut down the engine; this will prevent the
activation of the parking brake motor.
Also suggest you move to YVR to avoid salt and the frosty part
of the Great White North. Then again, the average price of a home
in Vancouver is about 750 grand CDN. You could buy a hell of a lot
of calipers for that.
Cliff
Old Aug 15, 2013 | 07:47 PM
YYZ's Avatar
YYZ
Thanks Cliff
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
