Brakes faded
Old Feb 6, 2013 | 05:50 AM
Angel Tsvetkov's Avatar
Default Brakes faded
Hello guys !
So uhm, 2 weeks ago i had my front brake pads changed. The brakes were outstanding after the change. But 5 days ago after i braked on a little downhill, the pedal faded. The pedal has to be pressed much more than normal, the car still stops but now its like its with old pads. When i depress fully, it starts skidding and activating ABS, it wasn't like that after the replacement, it didnt skid on a wet surfice! After the replacement i had to press the pedal lets say + - 2 cm., but now , wow , at least 5 cm. Its quite inconvinient. So any guess on what it may be from is welcome. I am pretty sure the brake fluid hasn't been changed since we own the car ( 5 years).
Old Feb 6, 2013 | 05:54 AM
JOsworth's Avatar
Your last sentence is my advice to you. Have the brakes inspected and fluid changed. A general rule of thumb is that it should be done about every two years.
Old Feb 6, 2013 | 06:04 AM
Thanks, will go to the service place as soon as i have some free time.
Old Feb 6, 2013 | 09:36 AM
Mikey's Avatar
Seems the problems started when the new pads were installed. I'd revisit that area to see what went wrong. Technically your brakes did not 'fade', you just have low or soft pedal. Usually not difficult to fix assuming good quality components were used.
Old Feb 18, 2013 | 02:39 AM
I went to the place that changed the pads (front only) and i said that the brakes got worse after a few days of usage and they started to squeak a bit.
They asked me how many THOUSEND kilometers i have driver after the pad change, and when i answered 500 km. max and they were like - Lol wut ?
They lifted the car and bled the brakes or whatever it is on the front only ( 3 minute procedure) and the guy said that the brake pedal feels good for him. We took it for a fast test drive with braking and let me tell you that NOW when braking fully from 100 km/h, the jag stop WAAAY SLOWER than my Mercedes 190D !!! the pedal still travels alot before meeting any resistance and actualy start stopping.
Is there a specific way of bleeding the system ?
Old Feb 18, 2013 | 02:55 AM
thebiglad's Avatar
If you are sure that the brakes are worse now than before the change of pads, I would take your car back to the brakes place and ask them to fix the problem.
Don't mess with it yourself or you'll get no comeback from the garage.
Old Feb 18, 2013 | 03:15 AM
Actualy the pedal faded 1 month before the pads were changed, after a series of hard stoping. Back then i though that i just overheated them but it stayed on since then. When they installed the new pads, it was perfect, little push and the car starts to stop, full press on the pedal and it felt like you hit a wall it was that fast at stopping. 3 days after and BAM, same as before. I made an appointment for today aswell and will explain the situation again. Braking performance is greatly reduced at the moment.
Old Feb 18, 2013 | 08:17 AM
Docuzzie's Avatar
JOS is right. That's what Jaguar recommends, replace the fluid every 2 years.
Old Feb 18, 2013 | 08:36 AM
Brutal's Avatar
Put a cover over the wheels to keep the sun off the brakes so they dont fade
sorry couldnt resist, brake fluid should be change every 2yr/24k, but it may be too late. There are 2 things that come to mind on this issue. Pads sucks and improper breakin made them that way or they just suck to begin with. And 2
dirt, bad brake fluid damage the seals and master cylinder bore. This causes internal bypass of pressure/fluid and lower pedal and poor performance. This can also be intermittent as sometimes it seals, sometimes not.
I would definitly bleed the brakes first and go from there. If you hard brake before the pads bedded in you need to change them. This is a issue with getting on pads to soon before they bed into full performance. I have ruin pads in high speed braking before and new pads and sometimes rotors are the answer. And bed them in properly next time before you "use" them
Old Feb 18, 2013 | 12:53 PM
Mikey's Avatar
Again 'brake fade' has a very specific definition in English, this is NOT your problem.
Sounds like you have two separate problems according to the post above
1) low/soft pedal
2) poor stopping power
which may or may not be interrelated. Changing the fluid will do no harm but it's not the cause of these current issues. As others have said, let the garage sort it out if you expect them to pay for their mistake.
Old Feb 18, 2013 | 12:59 PM
sprdav33's Avatar
I had the same problem when I bought my 03. The brakes work but the travel and softness is not to my liking. I replaced the pads and rotors which helped but still not up to par. I am planning on replacing the brake fluid next because I don't it has ever been done.
Old Feb 18, 2013 | 03:03 PM
The guys said that they will change the brake fluid and will get me a new master cylinder.
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
al_roethlisberger
Sep 21, 2015 08:15 PM
Jefro
Sep 15, 2015 01:44 PM
