Bricked PCM ERR 0xc
Old Jul 3, 2020 | 01:05 PM
Motorpot's Avatar
Default Bricked PCM ERR 0xc
Hello,
i'm Volker from germany and i'm driving a 1999 S-Type v8 since a short time.
unfortunately the PCM is locked, i use IDS and a mongoose cable and can not access the PCM.
even during configuration I cannot get a connection to the PCM
now i have read the Thread:
https://www.jaguarforums.com/forum/s...ed-ecu-226490/
and the article from motorcarman and found the file Jaguar 32-bit ECM recovery procedure.doc
unfortunately the pictures are missing and it is for facelift, 2003.
this also applies to pre facelift
how do i get back to the PCM?
thanks for your help, volker
Old Jul 3, 2020 | 05:51 PM
JagV8's Avatar
Is it a clone cable and/or a cracked IDS? They feel the most likely.
Next, have you checked the wiring, pins, fuses, etc for the OBD?
BTW you have a PCM sometimes known as a Ford PTEC / PCM150.
Have you tried an ordinary OBD tool to see if it can get normal OBD data?
Do you know how the PCM apparently got into what you call "locked"?
Also, a vital issue: have you checked your 4.0 has got the revised chain tensioners etc? It'll destroy its engine if not, sooner or later. Note: updating them is NOT an item carried out during any service but does need doing.
Old Jul 4, 2020 | 01:00 AM
Motorpot's Avatar
Hello,
it's a china clone mongoose cable, IDS is 130. not on vm.
Pinpoint test is done, wiring checked more than one time.
normal OBD can't connect.
i bought the car, it's been standing still there for nine years.
it has got the latest chain tensioners from me and runs good,
but it keeps giving the error message: transmission malfunctioned
and then shift harder.
Volker
Old Jul 4, 2020 | 09:04 AM
abonano's Avatar
Originally Posted by Motorpot
Hello,
Volker
You found your problem! No need to explain further. Stop using clone crap. You get what you paid for...
Old Jul 4, 2020 | 10:55 AM
Motorpot's Avatar
okay, t
hen I'll look for a good one.
configuring the ABS but worked.
what's the right procedure to configure the PCM?
Old Jul 5, 2020 | 07:49 AM
Motorpot's Avatar
can you tell me a source of supply for an "original" cable?
as far as i know, no originals have been built for several years.
unfortunately, used ones are also very rare, and how can i distinguish them from clones?
drewtech also does not offer cables anymore.
also very expensive new cables are china clones.
Old Jul 6, 2020 | 05:04 AM
abonano's Avatar
Ebay. Your looking for VCM or legit Drew Mongoose cable. Might need to take to a shop that already has the hardware.
Old Nov 28, 2020 | 08:28 AM
Motorpot's Avatar
Hi,
now i bought a VCM and i can read the PCM.
Thank you for help.
michael_101010
Dec 3, 2022 07:47 PM
SecretSupercarOwner
Non-Jaguar Vehicles
Feb 29, 2020 06:45 PM
Platinum XJR
Nov 13, 2019 10:10 AM
rjulius
Jul 12, 2019 03:31 PM
Ashton Dimovski
May 5, 2019 02:17 PM
