Broken pipe.. HELP!
Old Jun 5, 2016 | 10:30 AM
Stanners's Avatar
Default Broken pipe.. HELP!
This pipe here has snapped off and the rubber piece has fallen into the hole. It runs past the back of the engine and onto the brake cylinder (front left) of the engine behind the brake fluid tank. Does anyone know what this pipe is for and will it matter if the rubber has fallen down inside?
[/QUOTE]
Old Jun 5, 2016 | 11:51 AM
abonano's Avatar
[/QUOTE]
Vehicle and engine info please & a better picture..
Old Jun 5, 2016 | 12:21 PM
Stanners's Avatar
As my profile says, 1999 S TYPE 4.0 V8 auto. I'll upload a better pic later
Old Jun 5, 2016 | 12:48 PM
abonano's Avatar
Vehicle and engine info please & a better picture..[/QUOTE]
As your tread says "Broken Pipe...HELP"... Not many forum members (that use the mobile version anyway) are going to go the extra mile to look up your vehicle info I. Your profile...
Old Jun 5, 2016 | 01:05 PM
abonano's Avatar
[/QUOTE]
I logged in via my computer. Yes, I would disconnect this hose and fish out that broken plastic part. Then your going to have to source a replacement fitting.
This is more than likely an air line regarding your emissions and if you leave it "exposed" your going to set a DTC. Maybe you have enough meat on this fitting to get the hose back on unless it broke flush.
This is what I gather from your pic and not going out and looking at my car.
Old Jun 7, 2016 | 01:32 PM
JagV8's Avatar
if it's an air leak fix it fast - so it can't cause expensive damage.
Old Jun 8, 2016 | 09:26 AM
NBCat's Avatar
Based on the photo, you must replace the stub pipe and elbow sleeve going to the brake servo. The stub pipe carries JLR part number NCE3193HA, but has been discontinued. The elbow sleeve part number is NCE3254AA.
As parts may be superseded, always provide the VIN when ordering parts from a Jaguar agency.
You must repair the elbow as the vehicle will begin to run lean causing possible misfires and subsequent catalyst damage.
Old Jun 14, 2016 | 01:35 PM
Stanners's Avatar
That's a great help, Thankyou ever so much for your help! Lucky i just brought another s type which is a donor car so will take it off that. thanks once again
larney
May 27, 2016 07:28 PM
Per
Apr 11, 2016 08:04 AM
AW2Jaguar
17
Apr 6, 2016 11:26 AM
multiplecats
General Tech Help
27
Apr 5, 2016 09:42 AM
powerhouse
Apr 2, 2016 02:55 PM
