Cats system fault
Old May 15, 2019 | 03:54 PM
davidladewig's Avatar
Default Cats system fault
I unplugged the shock plug the other day while working on the cam cover. When I turned on the key, the Cats system warning came on. All hooked up and the warning still there. Battery disconnected for reset....Nothing. I read here to unplug the fronts, start the car and then replug them, start the car and it should clear.....Nothing. Any ideas how to clear this. The suspension is working fine.
Thanks.
Old May 15, 2019 | 03:58 PM
JagV8's Avatar
OE tool, I suspect.
Old May 15, 2019 | 08:20 PM
I turned the key on and then off and then on again and it went off. I'm sure that was bums luck and it will come back on. My scanner doesn't read a code but mine is basic.
Old May 15, 2019 | 11:33 PM
scottjh9's Avatar
I did the same thing...ended up clearing code with icarsoft930
Old May 16, 2019 | 11:36 PM
Scott
What model do you have and will it work and a 2000 S Type?
Old May 17, 2019 | 10:39 AM
scottjh9's Avatar
Originally Posted by davidladewig
Scott
I have the icarsoft i930....jaguar landrover specific....purchased on ebay...it covers 1999 and onward
Old May 17, 2019 | 01:16 PM
Thank you. I just ordered one. I appreciate the quick response.
Old May 20, 2019 | 12:58 PM
Update: icarsoft i930 arrived. Cleared the message in about a minute. Thanks to scottjh9 for the tip
bigdaddywuff
19
Mar 2, 2021 01:27 PM
alephzain
16
Mar 1, 2019 06:00 PM
jcboulos
Jan 28, 2013 05:25 PM
